Handy guide to the "proper" juxtaposition of inductors in crossovers
Saw this uploaded to Flikr & thought it was a simple and handy guide for anyone who's wondering about how to arrange inductors in a circuit to minimize any deleterious cross-coupling between inductors. :)
source: https://flic.kr/p/Mo3DfH
    F1nut Posts: 49,802
    Good post Mark. I saw someone's crossover upgrade recently that could have used that info.
  • gmcman
    gmcman Posts: 1,759
    @mhardy6647 Thanks for sharing that.
    So does this put the setup for some of our inductors in the "very bad" category? Or does the plastic framework reduce this cross-coupling?
    Web pic of 2.3TL factory inductor layout.
    mhardy6647 Posts: 33,046
    Any normal plastic should be invisibile to the electromagnetic fields around the inductors. Those two are at right angles, which is good -- their physical proximity is less good, but we're still not lookin' at a worst case scenario -- so all is probably fine.
  • delkal
    delkal Posts: 764
    Unless I am seeing it wrong it looks like number 4.............Very bad and worse case scenario
    VR3 Posts: 28,041
    That is proper placement, no worries
    That placement is not even on the chart and it is fine
  • gmcman
    gmcman Posts: 1,759
    VR3 wrote: »
    Unless I'm seeing incorrectly...looks just like fig 4 when rotated 90 deg.
    edited September 2018
    Some info from Pat McGinty (the "Meadolark" guy) on empirically testing for inductive coupling here:
    http://www.hifihaven.org/index.php?threads/a-little-pictorial-guide-on-the-juxtaposition-of-inductors-in-a-crossover-for-diy-or-refreshing.4024/#post-76833
    The problem with the juxtaposition shown in the photo a few posts back is the physical proximity of the coils. It's certainly not optimal, but it is probably, empirically, fine.
    VR3 Posts: 28,041
    My experience with measuring inductors says that it makes such a small difference that it won't matter
    VR3 Posts: 28,041
    I've found 2, 3 and 8 to be the worst
  • steveinaz
    steveinaz Posts: 19,522
    No, not like #4. His 2 are sitting on edge, neither is sitting flat.
  • gmcman
    gmcman Posts: 1,759
    For the record, I'm not doubting how well the crossovers work, and they do with the orientation in my pic..just comparing to the diagram.
    steveinaz wrote: »
    What if we take the pic and rotate 90 deg, then instead of looking at the top, imagine looking at the side...nearest the bottom of this pic.
  • ZLTFUL
    ZLTFUL Posts: 5,640
    The point is, they are 90* orientation from each other which helps reduce the inductive interference.
    Greater distance = OK solution
    90* = better solution
    90* + greater distance = best solution
    ZLTFUL wrote: »
    egg-zack-a-tack-ly.
  • gmcman
    gmcman Posts: 1,759
    ZLTFUL wrote: »
    I agree.
    This is also 90 deg. I want to say that #4 is not referring to this, but the 1st pic.
    And again, just curious if either way will make a larger difference, especially in our crossovers.
    I'm not complaining....speakers sound great. B)
    as a truism -- a little more space between inductors is better if circumstances permit. I like to give my DIY XOs room to breathe :) In fact -- why put 'em in the box at all? No real value added (especially if one wishes to... umm... experiment.
  • verb
    verb Posts: 10,176
    Interesting lesson professor. I found this. Right hand rule. Explains why the orientation and 90 angles can be placed closer together.
  • ken brydson
    verb wrote: »
    What is this about again?
  • ZLTFUL
    ZLTFUL Posts: 5,640
    verb wrote: »
    It's about the "flow" Ken!
  • delkal
    delkal Posts: 764
    All of the inductor photos are the same as what is shown in figure 4. And if the table is correct it is the worse setup. It doesn't matter if the inductors are placed flat side by side, tilted side by side or even on top of each other on a board. The only thing that matters is the orientation of the copper windings. It is number 4.
    You can se it easier if you put your pointer finger on each hand thru the hole in each inductor. Your fingers will be pointing in a T. No other orientation in the table will do that.
    But is this table correct?
  • delkal
    delkal Posts: 764
    VR3 wrote: »
    Do you take the measurement when BOTH inductors are hooked up, charged and have a current? Testing one inductor at a time won't show much of an effect. And if the neighboring inductor is not hooked up to anything it will have zero effect (no circuit for the coil to do anything). But when both inductors are charged and acting like a magnet thats when you will have a big effect.
    Viking64 Posts: 6,688
    I just want to eat doughnuts.
  • delkal
    delkal Posts: 764
    Viking64 wrote: »
    Put a doughnut on each pointer finger, look at the chart, play around a little, then eat them!
    If you still don't see it get the next two doughnuts...............
    delkal wrote: »
    Or maybe an electrolytic cannoli?
    F1nut Posts: 49,802
    gmcman wrote: »
    ZLTFUL wrote: »
    I agree.
    That is the same as #4 because the coils are going in the same direction. That is, if you stood up the one laying down it would be parallel to the one on end. Now, if the one laying down was stood up on end and turned 90 degrees that would be good.
    F1nut Posts: 49,802
    delkal wrote: »
    In gmcman's photo the coils are in a "T" configuration, which is ok.
  • agfrost
    agfrost Posts: 2,421
    gmcman's picture is "none of the above" when looking at the original diagrams. The SDA inductors are placed like this:
    Jay
  • delkal
    delkal Posts: 764
    Lets just say this is not a handy guide. It is either wrong with number 4 being very bad or that a lot of people can't understand the difference between number 4 and number 6.
    I've been up all night testing these various examples and I still haven't been able to sew the ripped 3/4 sleeve of my Captain and Tennille baseball shirt. :'(
  • agfrost
    delkal wrote: »
    Care to illuminate us as to who comprises "a lot of people?"
    Jay
  • agfrost
    ...I'll follow up my previous diagram with this one, which I posit is the same as number 4 (and different from the first one I posted). In essence an "L" instead of a "T".
    Not an electrical engineer nor a crossover designer, so I can't wax poetic as to why/how these are different, but my visual-spatial skills tell me there's a difference.
    Jay
