DCR Values??
Toolfan66
Anyone know what the DCR Values are for the 1.55 inductors??
Thanks!!
Just to clarify: what vintage of the M10 are you referring to? With or without the Velcro grill mounts? (I'm assuming it's a peerless tweet regardless)
#18 gauge, 0.67 ohms Larry.Home Theater/2 Channel:
dhsspeakerservice.com/ -
westmassguy wrote: »#18 gauge, 0.67 ohms Larry.
Thank You, I was hoping you would chime in, I almost just PM,ed you as I figured you would have the answer..
No Velcro, Yes Peerless, and mine have the MW6500’s not the MW6501’s that show on the schematics but everything else is the same.. The date on my Crossovers is 83..
Thinking I might have some fun with these, picked them up for a big whopping $25 for the pair, everything is in working order, they didn’t have the grills but but Brian had a latter set of cabinets that had the peerless as well, and he was kind enough to let me have them, so l want to get a little crazy with them.. -
I would expect nothing less than something a little crazyHome Theater/2 Channel:
I know make a dual center channel out of them....yea yea that's the ticket...
Climbing back down in my hole -
I was thinking on the way into work today, take 2 pair of 10s and Frankenstein a 3.1esque out of them (new cabinets of course).
Just tossing this out. I think the mw6500, mw6600 and mw6501 must be very very close in parameters because they were all interchanged in so many models and the next model had one or the other mw's in the next rendition. Anybody know the parameters of the mw6600/mw6500?
The mw6501 parameters was listed somewhere here on the forum. -
Driver: MW 6500 Driver's model #.
Brand: Polk Driver's brand name.
Fs: 31.0000 Hz (Free air resonance)
Vas: 2.6486 ft^3 (Compliance volume)
Qts: 0.2190 Total Q
Qms: 1.3000 Mechanical Q
Qes: 0.2640 Electrical Q
Sd: 0.0130 M^2 (Piston area)
Xmax: 3.1800 mm (Cone excursion, linear)
Revc: 6.5000 ohms (DC resistance)
Znom: 8.0000 ohms (Nominal impedance)
Pmax: 35.0000 watts maximum rated power
Driver: MW 6501 Driver's model #.
Vas: 2.7545 ft^3 (Compliance volume)
Qts: 0.2790 Total Q
Qms: 1.4700 Mechanical Q
Qes: 0.3440 Electrical Q
Revc: 7.7500 ohms (DC resistance)
Pmax: 35.0000 watts maximum rated powerHome Theater/2 Channel:
Awful close. I bet the mw6600 is right on top of one of these with a point or 2 difference.
