What should I add as a center channel speaker with my LSI 9?
Hey all, I am replacing my center channel for my 5.1 system, and I thought about getting the CSI A6 with my LSI 9. It's a good price and unfortunatley I can't afford the LSIm series.
What do you think about it?
Thanks for the help!
  • ken brydson
    ken brydson Posts: 8,650
  • guy1000
    guy1000 Posts: 7
    Umm, LSic?
    Do you think the extra 200 dillars are worth the difference?
  • 11tsteve
    11tsteve Posts: 1,166
    As opposed to what? No center?
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • mrloren
    mrloren Posts: 2,454
    Hello and welcome to the forum.
    If I remember correctly the LSi are 4 ohm speakers, CSi A6 is 8 ohm speaker. If you're just powering them with an AVR that might not be good for long term use.
    You should list your AVR and amps if they are being used.
    There are others on this forum that will have a lot more knowledge than I. Maybe they will chime in.
  • guy1000
    guy1000 Posts: 7
    11tsteve wrote: »
    As opposed to the CSI a6 which costs 240 :)
    by the way, i didn't say, i currently use the tl1600 center
  • guy1000
    guy1000 Posts: 7
    mrloren wrote: »
    So I currently have the tl1600 as surround and center speakers, and the lsi 9 as front. The AVR is Pioneer vsx lx302 :)
    F1nut Posts: 49,805
    edited August 2018
    You want the front 3 to timbre match. The CSiA6 is not a good match with the LSi9. In fact, it sounds nothing like the LSi9.
  • guy1000
    guy1000 Posts: 7
    So my only good option is the LSIC?
    F1nut Posts: 49,805
    Yes
    txcoastal1 Posts: 13,132
    A pair of lsi7's on their side if you have an amp with spare channel
  • warren
    warren Posts: 756
    I have a csi5 with my lsi9’s. Works great!!
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
    F1nut Posts: 49,805
    txcoastal1 wrote: »
    Yeah ok, that'll work too.
  • guy1000
    guy1000 Posts: 7
    Well it's hard to find the Lsic on the internet, but I did find some used ones for about 160$
    F1nut Posts: 49,805
    Well yeah, the LSi series has been out of product for a number of years now. The LSiM series replaced it.
  • ken brydson
    guy1000 wrote: »
    $160 is a good price IMO...
  • Mikey081057
    Mikey081057 Posts: 7,127
    There are some LSiC's available but you might want to consider getting rid of the 9's and parlaying that into another front group of speakers that would be easier to drive with an AVR
    Garage | Polk Monitor 5B's
  • dromunds
    dromunds Posts: 9,984
    Your Pioneer Elite receiver is 4 ohm rated. My GF is driving my LSi-9's with basically the same receiver, it does just fine, and she really likes those speakers. I like them also, (and the LSi-7's,) good bang for the buck at current prices - that's for sure. I may be incorrect, but I thought there were some LSi-C's recently in the "for sale" forum, maybe check and take a look back - although I may be remembering them from the "Looking for Misc Audio Deals of the Day" thread). They seem pretty easily obtainable in any event.
  • guy1000
    guy1000 Posts: 7
    You mean my reciever might have hard time with thr LSi 9 and the LSic?
  • Mikey081057
    Any 4 ohm speakers might be rough on a receiver
  • dromunds
    With the outrageous sale back on at Adorama for the LSiM 703's, it may indeed behoove you to pick up a pair for the 5 hundy (with free shipping) and sell the LSi-9's - even though I like the 9's, the 703's are a better speaker and at that price would mean you'd only have to kick in a bit after the sale of the 9's. I like the 9's a lot, but I have both and the 703's are virtually impossible to beat at that price. A completely re-designed speaker.
  • shs
    shs Posts: 105
    I use a 703 for my center channel with 705s on the left and right. Three 703s across the front would be awesome.
    SONY VPL-VW385ES, Da-Lite 92" 0.9 HD progressive 16x9 screen, Apple TV 4K, Oppo UDP 203, Anthem AVM 60, D-Sonic 4000 (800x3, 400x4) for bed layer, 2 Crown XLS 1002 (225x4) for Atmos; Speakers: Polk LSiM 705s, 703 front, 4 702F/X surround, 4 Polk TL3 (Atmos), Velodyne DD15 Subwoofer.
