Mytek Brooklyn Phono Stage
I'm trying to set up my phono stage in the Brooklyn DAC, but I'm not getting sound. I'm not sure what I'm doing wrong. Does anyone have any experience with this?
The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects
  • Mikey081057Mikey081057 Posts: 5,515
    Input has to be set to ANLG
    Phono Setting has to be set to MM or MC dependig on your cart.
    HT:Polk LSiM 706 LSiM 705's VR3 LSiM 703's LSiM 702's| Marantz AV7702 | Sunfire TGA-7401 | Oppo BDP-103D | Sony PS4 | Directv Genie HD DVR | Samsung 64" Plasma | SVS PB13 Ultra | MIT EXP 2's (Fronts & Center)
    ManCave: Parasound Halo A21 | Parsound Halo A52+ | Marantz AV7004 AV PrePro | Usher Dancer Mini-x DMD's | Usher BE-616 Center | SVS Ultra Surrounds | SVS SB4000 Sub |Oppo UDP 203 | MIT Shotgun S3's | Marantz SA8004 SACD | Music Hall MMF 5.3se TT w/ Soundsmith Carmen | Mytek Brooklyn DAC+ | HP Elite Slice PC | Samsung 50" SUHD TV | Sony PS4 Pro
    Patio Polk Atrium 8's |Marantz 2252B |
    Office Bluesound Node2 | Polk SDA SRS 2.3 | Marantz 2385 |
    Bedroom Peactree Nova 125SE | Focal 905's | Bluesound Node | SVS SB2000 Sub
    Garage Yamaha R-N303BL | Polk Monitor 5B's
    Closet Yamaha M80 | 2 Polk MP2K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's |
  • trav0810trav0810 Posts: 991
    edited July 30
    Both of those are done.
    Thorens TD320
    Modified Carver C-1
    Front Panel looks like this?
    Phono leads go into AINL and AINR.
    It was actually the outputs that was set wrong.. thanks for your help!
    Thorens TD320
    Modified Carver C-1
    Interested to hear your thoughts vis-a-vis other phono pre's you may have used.
    First impressions are good. I was using a bottlehead seduction a while back. Then I switched to a Mobile Find Studio phono. now I'm giving this one a chance. I haven't listened to it enough to really get into the nuances. But a first impression, it's not disappointing.
    Thorens TD320
    Modified Carver C-1
Howdy, Stranger!
