Mytek Brooklyn Phono Stage
trav0810
trav0810 Posts: 1,056
I'm trying to set up my phono stage in the Brooklyn DAC, but I'm not getting sound. I'm not sure what I'm doing wrong. Does anyone have any experience with this?
The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects
  • Mikey081057
    Mikey081057 Posts: 7,127
    Input has to be set to ANLG
    Phono Setting has to be set to MM or MC dependig on your cart.
    Garage | Polk Monitor 5B's
  • trav0810
    edited July 2018
    Both of those are done.
    Thorens TD320
    Modified Carver C-1
  • Mikey081057
    Front Panel looks like this?
  • Mikey081057
    Phono leads go into AINL and AINR.
  • trav0810
    It was actually the outputs that was set wrong.. thanks for your help!
    Thorens TD320
    Modified Carver C-1
  • Mikey081057
    Interested to hear your thoughts vis-a-vis other phono pre's you may have used.
  • trav0810
    First impressions are good. I was using a bottlehead seduction a while back. Then I switched to a Mobile Find Studio phono. now I'm giving this one a chance. I haven't listened to it enough to really get into the nuances. But a first impression, it's not disappointing.
    Thorens TD320
    Modified Carver C-1
