3 12" DXI subs
Hello and thanks for taking the time to read, answer and help if possible. FNG here and I should already know these answers but I am just getting back into the car audio since many many years.. Like 20 of them ago... So quite a bit has changed since then.. I have 3 12" Polk DXI subs 2 being dvc and one being svc... How in the world do I run these 3 subs together? I know I can run the two either series or parallel, but this last one has got me stumped. I was going to run it to a JVC Arsenal 1600 watt. Its a 4 channel amp, but on my head unit I only have a set for rear output and front, Pioneer AVH-290bt.. although It does say that switching the rear channel on radio there is a possibility of running a small sub. wonder how small or big it can go and would I need a signal output converter? I guess this is many questions in one.. my apologies... One more question... I have 2 Alpine VPower amps, both mono amps, one is 650 the other is 450,,, can these two amps be strapped or tied together to get maximum moPowa to my subs? thanks for reading my rambling. I would appreciate any answers that could or can be given. I am also planning on adding 4 10's.. Fosgates... and I have another 500 watt Phoenix gold amp to push.. running out of rca places here... haha
Thanks and Best Regards,
JP
  • FestYboyFestYboy Posts: 2,323
    edited June 9
    I'll start with: no, you can't strap those amps. Sry.
    Next I'll assume the SVC is 4 ohm and the DVC is 2 2 ohm windings (fairly typical). So if you want to run all 3, series each DVC to 4 ohm then parallel all 3 for a 1.33 ohm load to the amp (assuming 1 ohm stable). With your HU, run all 4 pres and use the JVC to run your components, then use the JVC pre outs to send signal to the mono block. The VPower should have a remote level control, if not then grab an AC Epicenter (better idea anyway).
    Edit for poor maths
  • pickettpickett Posts: 6
    well I will have to agree with you. I am building a box for the entire back seat. I've cut the angles and still in my r&d phase There isn't a lot to go off of the internet so its a WIP. fitting 3 12s , 1 15, 2 10s isn't an easy chore, then where to mount the amps... I will keep on keepin on and thanks for the info...
    If you're still building, I'll suggest that the 15 and 10s get separate enclosures as well. Trying to balance that mess within a single box will be a nightmare and will cause sonic issues and mess with the loading of the amps. May I also suggest that you get another VPower so that the amp display doesn't look unbalanced (also, I've use a phoenix gold before and wasn't impressed).
    by all means each sub will get its one box. I am a firm believer in sealed boxes. I am getting rid of two Memphis 12s shallow mount because I don't know a thing about inverting or even porting boxes. etc.... its a learning as I go on that stuff.
    *Screw it, TL the thing and call it a day! Lol
    right... Man I have looked all over the internet and tried to word and reword f150 supercrew back seat build, Ford supercrew sub box entire back seat.... dang... Nothin comes up with this... I have taken my entire seat out and I already have 2 of the boxes built but I don't think I have the right air space. Subs that I bought are either blown or about to be gone.. Not a big deal considering I didn't pay a hell of a lot for them. Plus I think that I will be using a different sub. Not that I don't like the ones I have, I like them tons.... But I don't think its the type sub I am looking for. Each sub has a unique sound.... I know I have enough air space for them. Could it be the way the box is shaped? If you took out the back 60/40 split on a 05 F150, cut the box in order to fit the back shape on the floorboard... I even lined the inside of the box with a dampening material and shoved some "cotton" up in there and it sounded okay for a few and then I heard a metal clank or metal to metal sound. No smoke no smell... Just a CLANK.... and I didn't have it up that high either. I have my dvc subs wired + - to amp and + - to opposite sides of sub. Nothing weird... just everyday wiring. I am thinking maybe not enough air space.. Hell I am about ready to throw my hands up and burn it all.... Boxes that is.... Not the subs.... lol.... I see in several spots where it says the Polk DXI 12 take about 1.5 cubic air space and in some it says .88... well what the hell... Make up your minds... OR at least make up my mind for me... Right now I have 1.5 that should be plenty... man o man... box dimensions are 16"L x 13"Wx 13H... I think that's it..
    should I join all three boxes and slot this thing out? I have 1200 watts to drive them, center box would sit on the hump. I can join all 3 together and cut a hole in each side.. Nicely though.. I am a carpenter by trade. or slot each box separately.... I don't really want that type bass....
  • mlistens03mlistens03 Posts: 986
    I think that the cabinet is too big rather than too small. When a subwoofer box is too big, it Basically is like running in no box. At least that is my understanding. Also, 1.5 might be the box size for a ported box, that seems rather big for a sealed box. I think that is correct anyway, I built a box for a kicker once a few years ago, and we made the box too big and it was like the driver was not in a box.
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    sure it has a flat response, and sure it has a lot of detail, and yes, it has good and clear lows. But is it enjoyable to listen to? Does it make you grin ear to ear? That’s what really matters.
    Seen somewhere on AudioKarma (I think)
    i believe .88 is the correct size. but turns out the sub is blown. 2 blown subs.... the original i picked up is still kickin.... Can i send these back to be rebuilt?
Howdy, Stranger!
