USB cable length
nspindelnspindel Posts: 5,287
I’m looking at feeding my DAC with a Mac mini located on my desk. I would need to wrap a USB cable around the room to do it, overall length would need to be about 35 feet to allow a little slack at each end. Can I get away with a USB cable this long without running into all sorts of problems?
  • EndersShadowEndersShadow Posts: 15,737
    I want to say it "might" work but the longer you go the higher the chance of dropouts.... also the pricier it gets to get a good cable..
    Does it have to be USB over say optical or coaxial? I think those work over longer distances than USB.
    @mantis will know, I think he even has mentioned it once or twice in his posts (so maybe do a search and see if it turns up)
  • mhardy6647mhardy6647 Posts: 18,369
    edited May 3
    Don't they make like line drivers and things for USB?
    That seems "dangerously" long for best results to me (just an opinion, though... 100% fact-free).
    EDIT: This kind of thing...
    https://www.amazon.com/Tripp-Lite-Extender-Transmitter-B202-150/dp/B003WO40V6
    Zero experience with such a gizmo, but it seems like a good approach(?).
    "It's like watching a roomful of people who couldn't get through college algebra discussing the flaws of quantum physics theory. I guess it could be fun, but it's ultimately a waste of time." -- seen on audiokarma
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
    "Writing about hifi is like dancing about architecture" -- paraphrasing some wag (possibly Frank Zappa)
    Also what DAC do you have?
  • ClipdatClipdat Posts: 4,212
    15ft max for standard USB cables.
    Got Dayens?
  • afterburntafterburnt Posts: 4,425
    edited May 3
    @EndersShadow I was using one with a repeater to my Oppo, I dont think it sounded too bad but it sounded a lot better just using an external HD.
    The consensus here seems to be you should t go over 3 meters.
    Will that Mac send a signal over the air? If not will one of the Chrome dongles work?
    Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
    Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
    Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
    Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
    Hello Kitty boombox
    Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
    Self Control is over rated.
    Mr. Sharpe wrote: »
    Meh these were extra $70 as an open box item so it didn’t much to me either way:)
  • mantismantis Posts: 14,939
    edited May 3
    At 35 feet your looking for some trouble. I suggest looking for a Active cable or a Balun. A Balun will extend USB over a Powered device to help along the signal. It's a device that you will have a USB A end on one side then a Cat 6 cable out the back then to another USB B device with Cat 6 IN and then USB B on the other side.
    This would be your best option. You could however try a 35 foot USB cable from like Monoprice and see if it would work, not how I would do it though but it's worth trying their cables are very low priced so the trial wouldn't cost much.
    In my world of Audio Video we don' run into long rubs of USB, our runs are usually .6 to 3m at best.
    Take a look at this
    http://www.ambery.com/usbovcat5cae.html
    Dan
    Hello Kitty boombox
    Mr. Sharpe wrote: »
  • nspindelnspindel Posts: 5,287
    Figured the answer was going to be something along these lines. Right now I've got a mac mini connected to my Marantz NA8005 via USB, they sit right next to each other on the rack. But now I'm setting up my desk on another wall in the room (25' x 15'), and would really like to move that computer over to my desk. I do have another mac that I can use at my desk, and have two machines in the room. But it seems like an awful lot of excess to have a fairly capable mac mini serving no purpose other than running jRiver into the Marantz with another one 10 feet away at my desk. But I'll need to run the wire along the wall around the corner, so it will end up a lot longer than 10 feet.
    edited May 4
    Your Marantz has optical and coaxial as well. Those might work on longer lengths than USB. I forget if they can pass as high a rez signal as USB. You also have a ethernet connection so if you can hardwire both to the same router that might work (assuming marantz has a decent web interface to control the music from while sitting on your computer)
    Here are instructions for your Marantz for Ethernet connection and control
    I’ve used the Marantz network streaming, and it does work. Until it doesn’t. Seems this unit gets itself confused from time to time when using the network capabilities, and it just locks itself up, and the only way to kick start it again is to unplug it. It’s functional, but annoying. Also the control of the unit is nowhere near as flexible as something like JRiver.
Howdy, Stranger!
