Marantz AMP-1 in the house!
verb
So I finally stepped into the digital rabbit hole!
Marantz AMP-1 integrated amp with their renowned DAC! Bad pic, but trying to hide the mess in the office!
Finally going to say goodbye to my Logitech 5.1 (using only 3.1) setup with the computer!
Oh yeah, generic audio output from the MB.
I have a pair of Acoustic Technolgies Classics that I'll use for my computer nearfield setup!
More to come!
More to come!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Cool - enjoy!
Love the looks. You need the matching CDP.
See if you can pry them off with a screwdriver.
So today I had the chance to hook up the AMP-1. Yay!
Paired with a set of new Acoustic Technologies Classic speakers. MIT Terminator2 cables. Office nearfield setup using my PC as source. Using iTunes at the moment (yes I know) with their lossless format.
So far so good! More impression to follow!
So today I started playing with the Marantz control panel in Windows7. This pops up. No info in the manual, none that I could find on-line. Anyone have any experience with it?
Latency values range from 1 - 32 msec
Buffer Size ranges from 64 - 32768 samples, or auto
The settings shown in the pic were default when I installed the driver.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Looks like a fairly typical driver for a USB audio interface. I have a similar one for my Numark V7 which is essentially a DJ style DAC.
I'd just leave them as is/default. Honestly you shouldn't even need the Marantz specific software installed. Unless perhaps for high res content playback?So today I started playing with the Marantz control panel in Windows7. This pops up. No info in the manual, none that I could find on-line. Anyone have any experience with it?
Cool thanks. I was playing with it a bit. It allows you to change the settings in real time, but no discernible difference to my ears.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Yep, should not have an aural impact which is why I'd just recommend the default setting. All it's controlling is the size of the buffer, and how quickly the computer should be filling it up.Cool thanks. I was playing with it a bit. It allows you to change the settings in real time, but no discernible difference to my ears.
Good to know. But since they put it there, I just had to play with it!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Here's another one. Default setting shown.
Options are 24 or 32 bit.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
That's what I tell the ladies2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
What is your primary source? I'm assuming it's 16 bit.
16 bit can populate/be carried by a 24 bit container. Unless you're playing high res 32 bit content I'd just leave it at 24.Here's another one. Default setting shown.
Think about that one like the visual difference between the NES and the N64...
But does the Marantz have "Blast Processing"!?
http://www.nintendolife.com/news/2015/11/the_man_responsible_for_segas_blast_processing_gimmick_is_sorry_for_creating_that_ghastly_phraseThink about that one like the visual difference between the NES and the N64...
Gotcha. The Queensrych SHM CD was remastered in 24bit.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
