Sda srs interconnect cable upgrade?
I'm currently using the ic that came with my sda srs. I hear it is worthwhile to upgrade this cable but it seems no one uses ends like the stock cable. Is upgrading this cable that beneficial? Is there any ends that are similar to the stock for a new ic. I know only one connection is required but I like how the factory cable plugs into the speakers
    pitdogg2 Posts: 24,582
    describe the ends. Blade/blade or Pin/blade
  • sansuibutch
    Mine are blade/blade
  • TNTsTunes
    TNTsTunes Posts: 751
    Blade/blade requires both connections. Pin/blade only needs one if a common ground amp is used. If a dreadnaught is used or needed both connections are required.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • sansuibutch
    TNTsTunes wrote: »
    Gotchya. So I do need both connections. What's the best route to get connectors like the factory ic wire?
  • TNTsTunes
    Speak-on connectors are used by many to replace the stock connectors so custom wiring can be used.
  • sansuibutch
    TNTsTunes wrote: »
    I did see people using these. Is it really worth it to upgrade the ic in General? I read that it makes for a bigger soundstage and so on. I'm not that convinced it makes a notable improvement seeing that polk used this ic in the first place. Again that's why I'm here asking all you fine folks that have much more experience than me. Do you have any idea what gauge wire is in the stock cable?
    stock is 16 gauge.
    I about 8 yrs ago called polk they sent out an aftermarket Blade/blade ends and I used Canare 4s11 cable.
    Only you can decide if it made a difference. The ends are not as nice as factory but they did what they were supposed to allow me to use larger gauge wire.
  • sansuibutch
    stock is 16 gauge.
    I appreciate the info. I was figuring the bigger/better wire would not make much of an improvement based on the little that the drivers for the sda effect do. But now that I know it's only 16 gauge wire and it's a pretty long cord il definetly put some thought into it. The speakers sound awesome as is. Looks like a few bucks and not a whole lot of time will get it done. Decisions decisions. Thanks again Pitdogg2
  • michaeljhsda2
    The Speak-on connection is much more secure because it locks into place, whereas the pin/blade connection is somewhat loose fitting and the blade/blade connection is much worse than that. I've always had problems with the blade/blade cable staying in contact within the socket since the day I bought my SDA 2's 30 years ago. Even tried spreading out the blades to maintain the connection and it still worked it's way loose. Terrible design.
    SDA SRS 2.3TL's
    SDA 2B TL's
    Viking64 Posts: 6,692
    Alright, who is going to be the first to mention dreadnoughts? :p
  • sansuibutch
    I must have gotten lucky for once in my life. Mine are very snug. I've never had a issue with intermittent connections or any funny business. But I just thought it was due to them so rarely being pulled in and out.
  • westmassguy
    westmassguy Posts: 6,850
    stock is 16 gauge.
    On your SRSs, the Interconnect carries the entire signal from the other channel. On later generations, the single pin connection carries the difference information back and forth. It makes a difference.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • westmassguy
    Viking64 wrote: »
    Not for those SRSs. 2nd/3rd generation SRSs can't use a dreadnought
  • sansuibutch
    stock is 16 gauge.
    It is not using the entire signal carried over is it? Or are you saying the entire signal is carried over and then uses some of the xover to work properly?
    F1nut Posts: 49,804
    Say what!?!
  • sansuibutch
    Say what!?!
  • westmassguy
    stock is 16 gauge.
    From approximately 2k down. The crossover filters the higher frequencies.
  • westmassguy
    Say what!?!
    On your SRSs, both blades carry signal.
  • sansuibutch
    stock is 16 gauge.
    That makes sense. Thank you very much.
    audioluvr Posts: 5,438
    Lots of variables here to consider also. Upgrading your IC's may NOT give you a discernable difference.
  • sansuibutch
    Can someone post a link to the correct speak-on connectors. I read some are air tight and some are not and so on. I would like to order these only once. Thank you
    Tony M Posts: 11,017
    What's your budget?
  • sansuibutch
    Tony M wrote: »
    What's your budget?
    $20
    edited February 2018
    "Parts Express" has some. "Mono-Price" might have some too.
    You're on your way. Good luck.
    But "cinch connectors" (?) might be better for you. You won't have to modify your speaker's connections. Only the cable.
  • RandyCroissant
    Mouser sells them as well
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • sansuibutch
    sansuibutch Posts: 198
    Today I received the parts to make my new cable. I've never used these speak-on connectors bwbed2fcz17sw.jpg
    efore so I have a question. Do I simply stick the wire in these holes and solder them or is there somthing I'm missing here? I don't want to melt these things
  • westmassguy
    You ordered the ones for solder connections apparently.
    These are the one I use:
    https://www.parts-express.com/neutrik-nl4fx-speakon-spx-series-4-pole-cable-connector--092-190
  • sansuibutch
    Nevermind. I downloaded the instructions and they do just get soldered.
  • sansuibutch
    I planned on soldering after I snugged the screws anyway I guess so no biggy there. What wires should I connect to what lugs?..my understanding is it really don't matter as long as there the same on both sockets and plugs, but if there is a certain way everyone does it for whatever reason it won't hurt that's for sure.
    F1nut Posts: 49,804
    I like the solder version best.
    Use one positive and one negative, then the same at the other end.
