POLK RTIA9 receiver??
So I have just got my pair of POLK RTIA9 for new year from Bestbuy, but I never had a receiver before. I was just looking it up online and I cant decide which one is better for my usage.
So I bought a new 4k TV as well, so I'm looking for receiver that can do the 4k passthrough and wireless connection. What kind of price range am I looking at?
I saw so many cheap receiver on craglist such as the VSX-830-K, Pioneer Receiver VSX-830-K, ONKYO TX-NR616 7.2 Receiver etc, but I don't know which one works and which one doesn't, please help :'(
«13
  • F1nutF1nut Posts: 40,206
    An AVR cannot power those speakers properly, they require a power amplifier, so look for an AVR that has pre outs.
  • oscar6220oscar6220 Posts: 15
    so I need to get an amplifier on top of the AVR? sorry im newbie on this :(
    edited January 5
    To properly drive that pair of speakers, yes. If you got the 7's the AVR alone would be sufficient.
    so technically speaking, I can buy any of the AVR listed above and get the proper amp to make it work? what kind of price range am I looking at for the amp please?
  • cfrizzcfrizz Posts: 13,006
    No you cannot buy any of those receivers and have them properly power your 9's. Neither of them have preouts to add a separate amp. You are really going to have to up your budget, or thing about getting used gear.
    It still won't be cheap, but better gear = having your speakers operate to their full potential, which will make you happy in the long run.
    Welcome to Club Polk.
    Sunfire TGP III PrePro, Sunfire Cinema Grand Signature 405wpc 5 ch. Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony Bravia KDL-40R510C TV, Polk S60 Main Speakers, Boston VR-920 Center Channel, SVS NSD-12 SB12 Subwoofer, Polk DSW 400 Subwoofer, Polk FXi-3 Surround Speakers
  • rooftop59rooftop59 Posts: 4,483
    If music is the primary purpose, you could start off with just this: https://www.ebay.com/itm/Yamaha-RX-V2500-Hi-End-Model-FM-AM-AV-Receiver-Amplifier-Great-Condition/152842835600?epid=50634581&hash=item2396249690:g:4ncAAOSw8apZgBKD
    It is a pretty stout receiver, tested well at audioholics and other places, and is neutral to slightly warm, which is good for your speakers. Plus it has preouts so you can add a beefy amp when funds permit. And that is a very good price. Any universal remote will run it.
    If you want HDMI, look for a 2600 or higher.
    HT Rig:
    Denon AVR-X4200w; Peachtree Audio Nova Integrated; Bryson BPD-1; Mains: Dynaudio Emit 10 + MartinLogan Dynamo (original) sub; Center - Polk cs400i; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - SVS PB10-ISD; LG UP870 4K BDP
    Master Bedroom
    Marantz SR-5007; Peachtree Audio NovaPre; Audiosource Amp Two, PSB Imagine B, Boston VR-10 center, NHT Super One CI surrounds, ACI Titan subwoofer, Squeezebox Touch
    edited January 5
    Even better, has HDMI 1.3 and a remote:
    https://www.ebay.com/itm/Yamaha-RX-V1800-7-1-Channel-130-Watt-Receiver/352216964712?epid=62078291&hash=item5201c45e68:g:CDQAAOSwxzdZ6lkg
    Not quite as powerful, but you still can use it for a while and then add an amp down the road. The 2500 might give you a little more cajones in the bass and slightly better dynamics, but not by much. I personally would go with the newer model...which is the 1800...
    HT Rig:
    Master Bedroom
    Ty for helping, I'm mainly looking at used gears now since I've just bursted 2.5k on the speakers and TV alone :/ there r sooooooo many to choose from but I've no idea how they work. Here is the list of AVR I'm looking on craglist
    Pioneer VSX-1131-K
    Denon AVR 889 7.1
    So none of the them works
    The pioneer will work, but I owned a similar one and the non-elite pioneers just sound wimpy and sterile compared to comparable denon, marantz, and yamahas.
    You need one that had at least six rca (red and white) outputs labeled either 5.1 or 7.1 preouts. This will allow you to add an amp down the road.
    If the TV is 4K with ARC and you want to use the built in apps to view 4K content but also want to best sound then you are in a different league and it is going to cost you to get both a solid amp with preouts and ARC. But if the TV also has a digital optical output, then you could use that to get sound from an older receiver.
    Get your read on, figure out what you need (or help us help you) and tell us your budget and we will spend it x2 lol...
    HT Rig:
    Master Bedroom
  • tonybtonyb Posts: 29,563
    oscar6220 wrote: »
    Pioneer VSX-1131-K
    Denon AVR 889 7.1
    Nope, none of them works on their own. The A9's are power hungry speakers, and most receivers simply don't have the power they need. That's why you need a receiver with pre outs, that enables you to add a power amplifier.
    You can hook them up to any of those, and music will play, but turn up the volume and your putting in jeopardy burning up the speakers, or receiver, or both.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
    Onkyo HT-R690 receiver Works?? Or is there any key words to find one that has 5.1/7.1 preout? Like a specific brand??
    Ty
  • DSkipDSkip Posts: 14,768
    edited January 5
    My Pioneer SC-63 would be about as good as you could hope for in powering those a9 off a receiver. It might still be higher than your desired budget though at $350 plus shipping.
    It also has preouts so you can add a dedicated amp later.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
    edited January 5
    Ok, here is a pic of the HTR690 Without preouts
    Here is a pic of one of Onkyo's newer receivers that does have preouts to add separate amp.
  • gp4jesusgp4jesus Posts: 1,164
    Can't tell you to find them but soon bunch of Outlaw 975s will come up on the used mkts as their owners are/will upgrade to the just released Outlaw 976.
    Samsung 60" UN60ES6100 LED
    Outlaw Audio 975 Pre/Pro
    Samsung BDP, DirecTV Rcvr, Xbox 360, Dennon LDP, Phillips CD chgr
    Canare 14 ga - LCR tweeters inside; CC outside
    BJC 10 ga - LCR mids, inside & out
    8 ga Powerline - LR woofers, inside & out
    LR: tri-amped RTi A7. Woofers, Rotel 98X amp; M & T, P'sound HCA-1000
    CC: Rotel RB985 -> tri-amped CSi A6
    5 Audio Pro Subs: 1 B1.39: 1 Evidence at each corner
    Surrounds: Hafler XL280 -> AR 12 ga -> RTi A3*
    3 dedicated 20A feeds; APC H15; 4 Furman Miniport 20s
    *Bi-amped by years end
    DSkip wrote: »
    DSkip wrote: »
    I can't tell really find any used Pioneer SC-63 at my area :/ I'm in vancouver if it helps. I mean if it's very good, I don't mind paying $400 tbh.
    Is it going to be a waste if my receiver doesn't have 4K pass through and I have a 4K TV or if there's other alternatives:"( I'm pretty stressed about it now
    There is no new receiver in the 400 buck range that can adequately drive the A9's. Plus your looking at another roughly 400 for a used amp. Your best option , cost wise, is to look for a used Pioneer SC receiver. That will get you by until you save the coin for an amp as long as you don't go nuts with the volume dial.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
  • nguyendotnguyendot Posts: 3,583
    Main Surround -
  • dolbyddolbyd Posts: 267
    DSkip wrote: »
    tonyb wrote: »
    Agreed.
    This is a good option for your 9’s. The last thing you want to do is clip the speakers and have repairs.
    The volume dial will need to watched for sure.
    We all have experience with what your speakers will need.
    They are awesome speakers for theater but it takes coin to make them their best and last for years to come.
    Some have learned the hard way.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 7704, OPPO 203, Emotiva XPA-5 Gen2, Emotiva X-500,X-150, Sony 75" 940E, Panasonic Plasma VT50,PS Audio Power Port X2, Perfect Wave AC-5 x4
    Office- Infinity Kappa 600, Kappa Center, in ceiling Polk RC80i, SVS PC 2000, Marantz 5010, OPPO 203, Emotiva X300, Sony 48"
    Master BR- LSi7, LSiC, LSI700 in ceiling, SVS-PC 2000, Marantz SR5012, Adcom 7500, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 55" 800B
    Workout room- RT2000P, CS1000P, Pioneer Elite SC81, OPPO 103, Panasonic Plasma VT 42"
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
    Storage room at this time- LS90, RT16, CS350LS
    So there's no other option other than the MARANTZ
    SR5011 and Pioneer SC 63? I found both of them on the east coast but shipping will be another headache
    edited January 6
    Those are suggestions, shipping won't cost that much. You can look in your own area too. Your local craigslist, US AUDIOMART, HIFI Shark, just some places to start.
    Basically you have too much speaker for the electronics you can afford. Might be better to return the 9's for the 7's. Which then you can use just about any of those other receivers.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    edited January 7
    Marantz SR5010 $750 or Refurbished SR5011 $650 are they fair price just wondering, ty... I kinda like the look of the Marantz, are they decent? :)
    Yes, those are excellent receivers. I would get the newer refurb version due to video specs. That’s seems like a high price to me, but stuff seems to be more expensive up there!
    HT Rig:
    Master Bedroom
    If you can get it shipped to you, this is very similar to the marantz (denon and marantz are owned by the same company, though they are developed in different departments by different people):
    https://www.accessories4less.com/make-a-store/item/denavrx3200w/denon-avr-x3200w-7.2-ch-x-105-watts-networking-a/v-receiver/1.html
    HT Rig:
    Master Bedroom
    alright, I think I'll go w the refurb SR5011. Is there anything else I need to buy or something I need to keep in mind? ty for everyones help, appreciated!
    one more question, if I buy a basic 14-Gauge Speaker Wire - 50 Feet, can I cut them in half, 25 to the left and 25 to the right?
  • pitdogg2pitdogg2 Posts: 10,564
    oscar6220 wrote: »
    Personally I'd go with 10 or 12 gauge if just using basic wire. Why would you need 25ft. to each?
  • Jimbo18Jimbo18 Posts: 1,788
    Return the RTi A9's and get the RTi A7's and use the savings towards a good AVR. Like @F1nut said, you can get by with just the AVR that way.
    Modest HT - Pio Elite SC-63, RTi 150, CSi40 center, FXi50 surrounds, Def Tech PF 15TL+, Belkin PF30, Samsung UBD-M7500.
    Even more modest Bedroom - HK AVR 340, Monitor 5jr+ Series2, CS300 center, Furez 10/2, Roku Premiere+
  • Viking64Viking64 Posts: 3,090
    Jimbo18 wrote: »
    Jimbo18, that dog is awesome! :)
    - Jimbo64
  • mrlorenmrloren Posts: 1,440
    Jimbo18 wrote: »
    I agree with the above, better yet get the A5 and a better AVR
    Family Room:
    Samsung UN60H,
    Denon AVR-X4400H, Emotiva BasX-A300
    Oppo BDP-93,Sony UBP-X800BM, Sony DVP-NS3100ES, WD Live HUB.
    Main: Polk Signature S60
    Center: Polk CSi-A6
    Front High/Rear High In-Ceiling Polk 80F/X RT
    Surrounds: Polk T15
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S35
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Polk RTi4 about 15' up the wall
    Old sony 12" Sub
    Mini tower PC with 400GB of music
«13
Howdy, Stranger!
