POLK RTIA9 receiver??
So I have just got my pair of POLK RTIA9 for new year from Bestbuy, but I never had a receiver before. I was just looking it up online and I cant decide which one is better for my usage.
So I bought a new 4k TV as well, so I'm looking for receiver that can do the 4k passthrough and wireless connection. What kind of price range am I looking at?
I saw so many cheap receiver on craglist such as the VSX-830-K, Pioneer Receiver VSX-830-K, ONKYO TX-NR616 7.2 Receiver etc, but I don't know which one works and which one doesn't, please help :'(
    F1nut Posts: 49,781
    An AVR cannot power those speakers properly, they require a power amplifier, so look for an AVR that has pre outs.
  • so I need to get an amplifier on top of the AVR? sorry im newbie on this :(
    F1nut Posts: 49,781
    edited January 2018
    To properly drive that pair of speakers, yes. If you got the 7's the AVR alone would be sufficient.
  • so technically speaking, I can buy any of the AVR listed above and get the proper amp to make it work? what kind of price range am I looking at for the amp please?
  • cfrizz
    cfrizz Posts: 13,415
    No you cannot buy any of those receivers and have them properly power your 9's. Neither of them have preouts to add a separate amp. You are really going to have to up your budget, or thing about getting used gear.
    It still won't be cheap, but better gear = having your speakers operate to their full potential, which will make you happy in the long run.
    Welcome to Club Polk.
  • rooftop59
    rooftop59 Posts: 7,966
    If music is the primary purpose, you could start off with just this: https://www.ebay.com/itm/Yamaha-RX-V2500-Hi-End-Model-FM-AM-AV-Receiver-Amplifier-Great-Condition/152842835600?epid=50634581&hash=item2396249690:g:4ncAAOSw8apZgBKD
    It is a pretty stout receiver, tested well at audioholics and other places, and is neutral to slightly warm, which is good for your speakers. Plus it has preouts so you can add a beefy amp when funds permit. And that is a very good price. Any universal remote will run it.
    If you want HDMI, look for a 2600 or higher.
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59
    edited January 2018
    Even better, has HDMI 1.3 and a remote:
    https://www.ebay.com/itm/Yamaha-RX-V1800-7-1-Channel-130-Watt-Receiver/352216964712?epid=62078291&hash=item5201c45e68:g:CDQAAOSwxzdZ6lkg
    Not quite as powerful, but you still can use it for a while and then add an amp down the road. The 2500 might give you a little more cajones in the bass and slightly better dynamics, but not by much. I personally would go with the newer model...which is the 1800...
    Game Room 5.1.4:
    Bedroom 2.1
  • Ty for helping, I'm mainly looking at used gears now since I've just bursted 2.5k on the speakers and TV alone :/ there r sooooooo many to choose from but I've no idea how they work. Here is the list of AVR I'm looking on craglist
    Pioneer VSX-1131-K
    Denon AVR 889 7.1
    So none of the them works
  • rooftop59
    The pioneer will work, but I owned a similar one and the non-elite pioneers just sound wimpy and sterile compared to comparable denon, marantz, and yamahas.
    You need one that had at least six rca (red and white) outputs labeled either 5.1 or 7.1 preouts. This will allow you to add an amp down the road.
    If the TV is 4K with ARC and you want to use the built in apps to view 4K content but also want to best sound then you are in a different league and it is going to cost you to get both a solid amp with preouts and ARC. But if the TV also has a digital optical output, then you could use that to get sound from an older receiver.
    Get your read on, figure out what you need (or help us help you) and tell us your budget and we will spend it x2 lol...
    Game Room 5.1.4:
    Bedroom 2.1
    tonyb Posts: 32,906
    oscar6220 wrote: »
    Pioneer VSX-1131-K
    Denon AVR 889 7.1
    Nope, none of them works on their own. The A9's are power hungry speakers, and most receivers simply don't have the power they need. That's why you need a receiver with pre outs, that enables you to add a power amplifier.
    You can hook them up to any of those, and music will play, but turn up the volume and your putting in jeopardy burning up the speakers, or receiver, or both.
  • Onkyo HT-R690 receiver Works?? Or is there any key words to find one that has 5.1/7.1 preout? Like a specific brand??
    Ty
  • cfrizz
    edited January 2018
    Ok, here is a pic of the HTR690 Without preouts
    Here is a pic of one of Onkyo's newer receivers that does have preouts to add separate amp.
  • gp4jesus
    gp4jesus Posts: 1,969
    Can't tell you to find them but soon bunch of Outlaw 975s will come up on the used mkts as their owners are/will upgrade to the just released Outlaw 976.
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • DSkip wrote: »
    My Pioneer SC-63 would be about as good as you could hope for in powering those a9 off a receiver. It might still be higher than your desired budget though at $350 plus shipping.
    It also has preouts so you can add a dedicated amp later.
    DSkip wrote: »
    I can't tell really find any used Pioneer SC-63 at my area :/ I'm in vancouver if it helps. I mean if it's very good, I don't mind paying $400 tbh.
    Is it going to be a waste if my receiver doesn't have 4K pass through and I have a 4K TV or if there's other alternatives:"( I'm pretty stressed about it now
    tonyb Posts: 32,906
    There is no new receiver in the 400 buck range that can adequately drive the A9's. Plus your looking at another roughly 400 for a used amp. Your best option , cost wise, is to look for a used Pioneer SC receiver. That will get you by until you save the coin for an amp as long as you don't go nuts with the volume dial.
  • nguyendot
    nguyendot Posts: 3,594
    Main Surround -
  • dolbyd
    dolbyd Posts: 430
    DSkip wrote: »
    tonyb wrote: »
    Agreed.
    This is a good option for your 9’s. The last thing you want to do is clip the speakers and have repairs.
    The volume dial will need to watched for sure.
    We all have experience with what your speakers will need.
    They are awesome speakers for theater but it takes coin to make them their best and last for years to come.
    Some have learned the hard way.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva X300, Sony 75" 940E, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA5 G2, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
  • So there's no other option other than the MARANTZ
    SR5011 and Pioneer SC 63? I found both of them on the east coast but shipping will be another headache
    tonyb Posts: 32,906
    edited January 2018
    Those are suggestions, shipping won't cost that much. You can look in your own area too. Your local craigslist, US AUDIOMART, HIFI Shark, just some places to start.
    Basically you have too much speaker for the electronics you can afford. Might be better to return the 9's for the 7's. Which then you can use just about any of those other receivers.
  • oscar6220
    oscar6220 Posts: 15
    edited January 2018
    Marantz SR5010 $750 or Refurbished SR5011 $650 are they fair price just wondering, ty... I kinda like the look of the Marantz, are they decent? :)
  • rooftop59
    Yes, those are excellent receivers. I would get the newer refurb version due to video specs. That’s seems like a high price to me, but stuff seems to be more expensive up there!
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59
    If you can get it shipped to you, this is very similar to the marantz (denon and marantz are owned by the same company, though they are developed in different departments by different people):
    https://www.accessories4less.com/make-a-store/item/denavrx3200w/denon-avr-x3200w-7.2-ch-x-105-watts-networking-a/v-receiver/1.html
    Game Room 5.1.4:
    Bedroom 2.1
  • alright, I think I'll go w the refurb SR5011. Is there anything else I need to buy or something I need to keep in mind? ty for everyones help, appreciated!
  • one more question, if I buy a basic 14-Gauge Speaker Wire - 50 Feet, can I cut them in half, 25 to the left and 25 to the right?
    pitdogg2 Posts: 24,548
    oscar6220 wrote: »
    Personally I'd go with 10 or 12 gauge if just using basic wire. Why would you need 25ft. to each?
  • Jimbo18
    Jimbo18 Posts: 2,314
    Return the RTi A9's and get the RTi A7's and use the savings towards a good AVR. Like @F1nut said, you can get by with just the AVR that way.
    Viking64 Posts: 6,677
    Jimbo18 wrote: »
    Jimbo18, that dog is awesome! :)
    - Jimbo64
  • mrloren
    mrloren Posts: 2,454
    Jimbo18 wrote: »
    I agree with the above, better yet get the A5 and a better AVR
  • gp4jesus
    oscar6220 wrote: »
    Go for the 10 gauge. 10 gauge will fit all Polk speaker' binding posts.
