Plasma buzzing
EndersShadowEndersShadow Posts: 15,659
edited December 2017 in Electronics
I know a few of us have or still have Panasonic Plasmas.
Early this morning mine started developing loud buzzing sound from the rear panel.
It still works fine but it’s driving me batty as I can hear it 10 feet away if I mute the TV.
I’ve holding my hand against with the flimsy rear panel and that makes it lower but then I goes back up when I let go.
And weirdly turning down the contrast helps a bit too, but I can only go so low
Is there anything I can do to do to fix this?
  • BlueMDPickerBlueMDPicker Old Polk Posts: 6,980
    We've had our 58" Panasonic plasma since 2006. While I can't offer a possible reason for the buzzing you're experiencing, the good news is the TV is completely modular with respect to various controller boards. I have replaced the digital input board on ours two times due to electrical surges caused by nearly direct lightning strikes. So, if you can isolate the noise source, perhaps it's something you can fairly easily replace? Hope so. Good luck!
  • Viking64Viking64 Posts: 2,676
    I have yet to experience anything like this on my TC-P65S2 that I bought in 2010. I did replace the YMAIN board in 2013, which was a common issue with those models.
    And I agree with BlueMDPicker. The boards are fairly easy to replace. The larger the screen, the easier, as things aren't so cramped as they are on the smaller models. Although the larger models tend to have costlier parts.
    Doing a Google search of the model number and "buzzing sound" will likely bring you to a forum with a wealth of information. And once you find what part is the culprit, there is probably a YouTube video showing how to replace it. :)
  • mrbironmrbiron Posts: 4,756
    Mine buzzes. I just turn up the volume. ;)
    My screen fluctuates as well.
    Zu Audio Omen MK-1B's, Peachtree Decco65, Bryston BDA-2, Cheap TT, PS Audio UPC200, PS Audio AC3's, Zu Mission SC's, HTPC, One, Bottlehead Reduction & Crack w/Speedball
  • ken brydsonken brydson Posts: 6,962
    Never an issue with mine. Looking for an excuse to replace it. No luck (wife)
    HT/Main- Panny 50" G10 Plasma, Pioneer SC-1222k AVR, Panny DMP-BD60 BDP, Polk LS90 mains, CS350LS center, LS/fx side surrounds, LS50 surround backs, SVS 25-31PC+ sub, Harmony One
    Office Rig- Marantz 2252B, Denon 2910, Kenwood KD2070 TT, Polk RTA 12B's/ RTA8t
  • EndersShadowEndersShadow Posts: 15,659
    From what I'm reading, its likely the ferrite cores on the unit vibrating against the flismy metal on the back.
    If this thing wasn't wall mounted (and 100+ lbs), I'd pull it off, take the back off and then either dynamat the OUTSIDE of the back, or do what the suggest, which is wrap the back of the cores with electrical tape and then put the back on.
    Maybe next weekend when I have friends over, I will think about it.
  • F1nutF1nut Posts: 39,806
    There are small fans back there, it's possible one of those is bad.
  • sgmsmgsgmsmg Posts: 298
    It might also just the area where the fans are need cleaning.
    Pre:Bryston BP173
    Amp:Bryston 4B3
    Speakers: Golden Ear Triton One
    Source: Oppo UDP-205, Mac Mini, Bryston BDA-3, Bryston BDP-3
    Cables: Wireworld Silver Eclipse 7 Speaker, Wireworld Silver Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Panasonic TC-P65ZT60
    Reciever: Yamaha CX-A5100
    Amp: Parasound A21, A31, A51
    Speakers: Polk LSiM 703 (FL, FR, RL, RR), Polk LSiM706 (Center), Polk 900-LS (Atmos)
    Subwoofers: SVS SB13 x 4 +DSPeaker Anti-Mode Dual Core
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Rocket 88, Pangea SE XLR
    Power: PS Audio P5 Regenerator, Furman IT Reference 15i, Pangea AC14SE and AC9SE Cables
    Display: Sony XBR75X940D
  • Mine always buzzed a little. More when DC was present on the line.
  • My Panasonic plasma always buzzed when I dimmed the recessed lights in my room. The more I dimmed the louder the buzz became, which totally went away once I turned the lights off. Is there anything on the line, even in another room that may be causing the noise?
  • Holiday lights?
    Rich502 wrote: »
    Now that you mention it we do have Christmas lights we JUST put up.
    That said, the TV and my two amps are on dedicated 20 amp circuits so the house would have to be going to he panel then back onto the TVs circuit
    Could it be electromagnetic induction associated with holiday lighting?
  • jeremymarcinkojeremymarcinko Posts: 2,961
    Could be any DC on the mains. I have an Emotiva CMX2 that eliminates DC, which I purchased for an ATI amp that was susceptible to tranny buzz from DC. Prior to the CMX2 when the Amp buzzed so did the plasma. As you said the brighter the picture the louder the buzz.
  • EmlynEmlyn Posts: 2,062
    If it is the Christmas lights it would be because of EMI coming from the unshielded wires. As long as they are plugged in it could cause interference regardless of the electrical circuit being different. Unplug and see if the issue resolves.
    My guess though is a dirty fan wobbling. If reachable, a can of compressed air may resolve it.
    1. Polk LSiM707, 704C, 703; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A23 amp; Oppo 205; Toshiba HD-DVD Player; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables
    2. JM Labs Electra 920.1; Parasound JC2 Preamp; Sonic Frontiers Power 2 amp; Sony HAP-Z1ES; Oppo 105D; Music Hall MMF7 and Acoustech phono pre; PS Audio P1000; MIT S1 Cables
    3. Polk LSiM703; Pioneer Elite SC97 receiver; Oppo 203; Squeezebox Touch; MIT S3 cables
  • txcoastal1txcoastal1 Posts: 9,667
    nbrowser wrote: »
    Buy a cheap Ninendo Wii on craigslist...get a sports game and "accidentally" chuck the controller at the screen while playing....bowling! Hard as possible...then go buy a new TV. :)
    Ken you forgot one thing....blame it on the kids B)
    nbrowser wrote: »
    txcoastal1 wrote: »
    nbrowser wrote: »
    Ain’t no got no money to replace it with fellas.
    Weirdly enough later yesterday the HDMI 1 inputs started looking weird and grainy, so we switched to HDMI 2, and the picture is back to good, and by adjusting the contrast down a bit the humming is gone.
  • tonybtonyb Posts: 29,211
    nbrowser wrote: »
    txcoastal1 wrote: »
    nbrowser wrote: »
    Hope you realize Dan, that set is on it's last legs. After the new year, start looking on your local craigslist for another tv on the cheap.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
    tonyb wrote: »
    nbrowser wrote: »
    txcoastal1 wrote: »
    nbrowser wrote: »
    I’m gonna price out a new HDMI board as I very much like the set.
    Maybe move it to the loft and find a Insignia or Visio 60+ tv for downstairs or something. I’ve been fairly impressed with my other two Insignias.
    They were running $125-$140 used/refurbished when I replaced mine. Never ran across a new one. Make sure you find the exact board number for best results. On my set, there were 4 variations (designated via suffixes) of the HDMI I/O board.
    Good to know. Any reputable sources for boards or ones to stay away from?
    Lol! Just checked my bookmarks and BOTH the companies I've purchased from seem to be defunct: tristatemodule.com and moduslinkptstvboards.com
    Tough business!
    Once you get the exact board number, you might try a saved search on eBay until one pops up. Good luck. You'll be a huge fan of their circuit design engineers when you've completed the fix.
Howdy, Stranger!
