Signa S1 Issues...
Hey, so I've been having some troubles with my Signa S1 and subwoofer- They used to work perfectly well, but now there's no sound at all- It's all plugged in correctly and is receiving power, It's not muted and I've messed with the volume, still no sound. I've un plugged it and plugged it in again, nothing seems to work- can anyone help me out?
  • KennethSwaugerKennethSwauger Moderator Posts: 6,538
    Hello,
    Welcome to Polk's forum. The best approach would be to contact Polk at 1-800-377-7655 select option 1, have the unit's serial number available when you contact them.
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
  • rsnowtenrsnowten Posts: 1
    Hello,
    I’m having issues with the volume Turing itself up, and the you can’t turn the power off with the remote or from the bar itself.
Howdy, Stranger!
