Sda srs 2.3 speaker/amp question.
I'm currently running 2.3 non-tl speakers. I'm getting a Bryston 8b amplifier. It's rated 120x4,or 400x2 bridged 8 ohm. Will this work,since running bridged,or mono seems to be an issue with many amps.
    F1nut Posts: 49,804
    It won't work with the speakers in bridged mode.
  • bassfann
    bassfann Posts: 151
    What's the reason ? Can I run dual mono amps ? Just trying to see what my options are.
    F1nut Posts: 49,804
    Once bridged it is no longer a common ground amp.
    Most dual mono amps are not common ground. Sharing the ground basically defeats the purpose of being dual mono.
    If you can buy an AI-1 SDA cable or make a Dreadnought you can then use any damn amp or amps you please. SDA's actually sound better using one those with a common ground amp.
