Anyone ever heard of this??
polrbehrpolrbehr Posts: 2,018
edited September 2017 in Going Digital
https://www.amazon.com/brennan-Brennan-B2-500Gb-Metallic/dp/B017Q9MMRG/ref=sr_1_8?s=electronics&ie=UTF8&qid=1504892497&sr=1-8&keywords=brennan+b2
http://www.thebrennan.com/
I was combing through YouTube yesterday and an ad came up for this thing from Brennan.
Normally I wait the lousy 5 seconds and click the Skip Ad button, but this one I actually watched for the whole 1:30.
Seems like a pretty decent way to access/save music, it supposedly can rip CDs directly to the internal HD, other options as well. For less than 5 bills a 500gb version can be had.
Opinions?
  • mhardy6647mhardy6647 Posts: 16,051
    What does it do that one cannot do with a 'pute (and keep $500 smackers in one's pocket)?
    PS The above is meant as a legitimate question, not snark. I..e., what is the value add over stuff (hard- and software) one might already have on hand?
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
  • DSkipDSkip Posts: 13,900
    If it were good quality, it would decrease the noise floor over a computer. In this case, I suspect it does nothing unique and doesn't separate itself from the competitors soundwise. It isn't unreasonably priced, but you can get this done by simply ripping to your computer and streaming to a cheap streamer and get similar, if not better, results.
    audiothesis.com/
    Speakers: Harbeth: P3ESR, 30.2, SHL5+; Usher: CP-6311, Be-10, T-515; Rosso Fiorentino: Elba, Fiesole, Volterra; Polk: T50, Signature S60, S55, S35, S30, S20, S15, RTA 15tl, Sonner Audio Allegro Unum
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Dayens Ampino, Triode Corporation TRV-88SER, MastersounD: Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, AURALiC Altair, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • polrbehrpolrbehr Posts: 2,018
    I already run a Squeezebox Duet, fed from a networked PC; no complaints about it other than an occasional buffer issue (seems like my new router eliminated that).
    This thing just looked intriguing, I might be tempted to do an A/B with it, but I do wish the price was a bit lower.
  • cfrizzcfrizz Posts: 12,771
    The few reviews that were posted on Amazon were not favorable. I suggest you keep looking.
    Sunfire TGP III PrePro, Sunfire Cinema Grand Signature 405wpc 5 ch. Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony Bravia KDL-40R510C TV, Polk S60 Main Speakers, Boston VR-920 Center Channel, SVS NSD-12 SB12 Subwoofer, Polk DSW 400 Subwoofer, Polk FXi-3 Surround Speakers
  • From the pic of the back shows some outputs/inputs missing that are labeled. Cat 5 not available but labeled, and Coax not available but labeled.
    Family Room HT 7.2/i]:
    Vizio P55-E1UHD Pioneer Elite VSX 32 Pioneer Elite BDP 85FD Pioneer Elite DV 47Ai Pioneer Elite N-50 Panamax M5300-EX
    Living room 2ch:
    Integra ADM 2.1 Teac EQ MKII Squeezebox Touch Fluance SX Speakers Panamax M5100-EX
    Upstairs media room:
    Vizio D1 32"Sony STR DG510 Sony PS4 Squeezebox Touch Polkaudio Monitor 40 II fronts Polk CSR Center Pioneer 8" sub Panamax M5300-EX
    Master bedroom:
    Vizio VF550M Pioneer Elite VSX 33 Pioneer Elite BDP 80FD Squeezebox Touch Polk audio Monitor 40 II fronts, Rears Optimus LX5s Jensen CCS center Acoustic Audio sub Panamax 5100
  • Viking64Viking64 Posts: 1,460
    The USB ports are labelled "USB A", "USB B", and "USB C", but judging from their size and shape, all 3 are USB A ports.
Howdy, Stranger!
