New receiver for RTi-A5
Hello
My current Pioneer VSX-920 is giving me trouble with video switching (hdmi)
Anyway, I purchased it cheap 7 years ago, and now with my recent RTi-A5, it's maybe time to get something much better
But I want to find a receiver that is not too deep...I was thinking about the Marantz SR5011 from A4L for $550
Is this a good pick? Any other recommendation in that price range, and not too deep?
RTiA5 + CSiA4
No surround...yet
Pioneer VSX920
  • andrew82andrew82 Posts: 152
    Sounds like a good pick to me. Polk specifies a 50w-250w per channel amplifier for the A5s, so the SR5011 would do just fine. I liked my Marantz receiver for sound signature and functionality.
    Personally-especially if you're just running two speakers-, I'd get one of Marantz's NR slim line and splurge a bit on an added amp. Would solve any questions you have about power and give you the AV capabilities you're after.
  • French_guyFrench_guy Posts: 222
    I have the 2 towers and 1 center (Csi A4)....No surround for now, but plan to add surrounds as soon as I can
    I've also read good things about Denon AVR 3300W....but it's deeper
    RTiA5 + CSiA4
    No surround...yet
    Pioneer VSX920
  • Jimbo18Jimbo18 Posts: 1,726
    They have a Yamaha Aventage RX-A760 for $449 with an egg on it. Supposedly $20 off when it has an egg. Lots of good reviews on here for their Aventage line.
    I think the Marantz is a better receiver but if you want to save a few bucks, this is a good option.
    Modest HT - Pio Elite SC-63, RT800i, CS400i center, RT25i surrounds, Def Tech PF 15TL+, Belkin PF30, Samsung UBD-M7500.
    Bedroom - HK AVR 340, Monitor 5jr+ Series2, CS300 center, Furez 10/2, Roku Premiere+
  • mrlorenmrloren Posts: 1,343
    edited May 2017
    I liked what my Marantz SR5010 did for my RTi8. really warmed them up a bit. So far I like my Marantz with the signatures too.
    The down side to the Marantz is the Audyssey, takes a bit to dial it in.
    For the Yamaha, I was told to not to mess with the 7XX or 8XX and only go for the 10XX and up.
    Family Room:
    Samsung UN60H,
    Marantz SR5010, Emotiva BasX-A300
    Oppo BDP-93,Sony UBP-X800BM, Sony DVP-NS3100ES, WD Live HUB.
    Main: Polk Signature S60
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk MC80
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S30
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Polk RTi4 about 15' up the wall
    Old sony 12" Sub
    Mini tower PC with 400GB of music
  • rpf65rpf65 Posts: 1,664
    The 5011 will work well with the RTI A5's.
    Can get the 5010, refurb, on Amazon for less than $500, think only 1or 2 HDMI's are 2.2 capable though. May want to look into it.
  • nbrowsernbrowser Posts: 7,914
    rpf65 wrote: »
    As a Marantz/RTiA owner...I agree, the combination soundwise is magical and very easy on the ears. The SR5010/SR5011 will have more than enough beans for the RTiA5 speakers. Also on the SR5010...all HDMI ports are 2.2 capable...not just one or two. :)
    Living room: Samsung UN55KU7000 4K UHD HDR 55 inch TV, Marantz CD6004, Pro-Ject Debut Carbon, Parasound zPhono, Mac Mini, Oppo BDP-93, XBox One S 2Tb, Kenwood DPX792BH car deck for radio purposes, Marantz SR5010 AVR, Parasound HCA-1200II, Front SDA 2 modded with Larrys Rings and RD0-194-1 tweeters, Rear Onkyo SKF-4800 Towers, Center CSiA6, BOOM Tannoy TS2.12 Sub, Audioquest Evergreen interconnects just about everywhere except from AVR to amp, MIT Terminator 4, MIT AVT3 speaker cables with extra terminals covered up Monitor 5 Jr+ in the wings for a center channel.
    The Denon AVR-3300X is $100 more than the Marantz.....Is it worth it?
    RTiA5 + CSiA4
    No surround...yet
    Pioneer VSX920
    edited May 2017
    My money, my ears? Marantz all the way with the RTiA series. It's warmer and fuller bodied than the Denon as far as sound signatures go. A nicer match if you will. 5 watts a channel is literally nothing to write home about.
    It's not really about the 5W difference, but more about the Denon having the Audyssey XT32...I've heard it was a big improvement over the Audyssey XT !
    RTiA5 + CSiA4
    No surround...yet
    Pioneer VSX920
    Honestly, I would worry too much about the room correction. I've used both XT32 and currently use Anthem's ARC (regarded as the best or at least, among the best). Really, I'm not sure what the difference is, but I can tell a difference between the two receivers' musicality and tone.
    Again, depends on what you use it for.
    Between the Denon and Marantz.
    If you want to focus more on the music side; Marantz.
    If the focus is HT; Denon.
    It will be more HT oriented, but I will also use it for music....Let's say 80% / 20%
    For music, I like jazz and also female vocals (Lisa Gerard for example)
    I like the Marantz SR 5011 for it's relatively short depth....
    RTiA5 + CSiA4
    No surround...yet
    Pioneer VSX920
  • PixOttPixOtt Posts: 15
    Hi All, sorry this post may be repeated. I have a Onkyo Receiver HTR-393 with 110 W at 6 ohms. I am planing to buy a pair of RTia5 from my colleague which is rated as 8ohms which I think is okey to work with my receiver. But regarding the point of power output, this Onkyo receiver can do its part? My room is only 20 feet X 30 feet. I am getting this pair at very cheap price, as my colleague is upgrading to B&W. Any answer and help is highly reply appreciated.
    https://www.cnet.com/products/polk-audio-rtia5-speaker/specs/
    PixOtt wrote: »
    No that Onkyo is a small unit made more for home theater in a box stuff. The specs on A4L says it's 65 watts not 110. https://www.accessories4less.com/make-a-store/item/onkhtr393/onkyo-ht-r393-5.1-ch-x-65-watts-bluetooth-a/v-receiver/1.html?gclid=EAIaIQobChMIj-iP8pqr1wIVQm5-Ch0sYgUkEAQYASABEgKMnfD_BwE#!more
    I would look more at a Denon, Marantz or Yamaha. If you're getting a good deal get the speakers and save for a better AVR. If you hook up the RTi to the Onkyo don't turn it up.
    Family Room:
    Samsung UN60H,
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk MC80
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Old sony 12" Sub
    The RTI A5's are pretty easy to drive. Two channel only, in a room that size, will probably get you a moderate amount of sound. probably somewhere you're tempted to go a little louder.
    That Onkyo is made for small bookies and satellite speakers. Entry level, low powered AVR's are notorious for causing the magic smoke to leave speakers. Wouldn't go above halfway on the volume knob, just to be safe.
  • nguyendotnguyendot Posts: 3,583
    "only" 20x30? That's a huge room considering the power you're putting in.
    Main Surround -
  • rooftop59rooftop59 Posts: 4,219
    Yea I didn't see the room size before, and didn't look carefully at the receiver. Again, if you crossover at 80hz and keep the volume in check you should be okay, but the sound will be disappointing. It will be thin and shrill because you are underpowering already bright speakers.
    HT Rig:
    Denon AVR-X4200w; Parasound HCA-1205A; Arcam rDac; Mains: Dynaudio Emit 10 + MartinLogan Dynamo (original) sub; Center - Def Tech Procenter 1000; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - SVS PB10-ISD; Sony BDP-S390, FireTV gen 2
    Master Bedroom
    Marantz SR-5007; Audiosource Amp Two, PSB Imagine Mini, Boston VR-10 center, NHT Super One CI surrounds, ACI Titan subwoofer, FireTV, Arcam rDac; Bryson BPD-1
    PixOtt wrote: »
    mrloren wrote: »
    PixOtt wrote: »
    ________________________________
    hi rooftop59 thanks. yes u r right. thats for HTIB..right now I have no money for a new AVR, but ofcourse I have to buy one. Do you have any specific recommendation? Denon?
    nguyendot wrote: »
    yeap only 20X30. :expressionless: nit sure what to do.. its nice set of speaker.. :smile: tempting!
    It's all up to you. If you're getting a deal on the speakers for like around $200 then I would say do for it. Put them in a closet for a few months and save some bucks.
    A4L sell referb AVR for a good price. Some have had bad luck while others have had good with them. Here are a couple of AVR's I would look at.
    https://www.accessories4less.com/make-a-store/item/denavrx2300w/denon-avr-x2300w-7.2-ch-x-95-watts-networking-a/v-receiver/1.html
    https://www.accessories4less.com/make-a-store/item/denavrx3300w/denon-avr-x3300w-7.2-ch-x-105-watts-networking-a/v-receiver/1.html
    https://www.accessories4less.com/make-a-store/item/marsr5011/marantz-sr5011-7.2-ch-x-100-watts-networking-a/v-receiver/1.html
    https://www.accessories4less.com/make-a-store/item/yamrxa760bl/yamaha-rx-a760-7.2-ch-x-90-watts-networking-a/v-receiver/1.html
    What are your end goals with what you are planning? 2 channel? 5.1 HT setup?
    This rabbit hole can get costly, Budget, look for deals and save.
    Family Room:
    Samsung UN60H,
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk MC80
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Old sony 12" Sub
    mrloren wrote: »
    Thanks a lot mrloren; I will look for 5.1 channel Receiver as I have got a center speaker and a sub. maybe I will put the Onkyo for sale. Learned a lot for you. :) Thanks a lot for the recommendations.
  • Still looking for a receiver for my RTi A5...A friend of mine purchased the Denon ARV S930H, and says it's nice. I was thinking first for a Marantz SR5011, but then read reviews about the Denon Denon AVR X3300W......that has Audyssey XT32
    Which one should I get (I would say I do 80% HT and 20% music)
    RTiA5 + CSiA4
    No surround...yet
    Pioneer VSX920
    Both are good choices and will drive those A5's pretty well.
    The Denon has a few more features for HT, but is slightly on the bright side, in my opinion. The Marantz is slightly laid back, again in my opinion, and I like it better for music.
    edited November 2017
    I have the SR5010, When I first got it I had RTi8's it did calm down the harshness on music a lot. It took movies to a new level over my Sony ES it replaced.
    The guy who I sold my RTi8's to got the Denon X3300W. It's a very nice AVR and Audyssey XT32 is nicer to dial in than XT. I think the only settings I had to change we set the speakers to small and crossover to 80hz.
    I have my SR5010 all dialed in now but it was a lot of trial and error. If I were to do it all over again I would get the Denon with XT32
    Family Room:
    Samsung UN60H,
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk MC80
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Old sony 12" Sub
  • I have the dennon avrx3300 and I have been very pleased with it, nice little receiver. Audssey xt32 is very nice. As said switch large to small I have the s60 towers set to small at a cross over of 80. Still playing though
    OK, I still haven't replaced my receiver (Pioneer VSX 920), but yesterday my daughter wanted to use the XBox, and it was doing weird sounds !!! Guess it's dying, and it's time to replace it
    I was originally looking for the Denon X3300W or Marantz SR5011 (both at $500 at A4L), but I've had unexpected expenses recently, and I'm know looking at something slightly less
    What about the Denon X2400H, or even cheaper the S930H? Or any other recommendations? (running 3.1 for now, will probably upgrade to 5.1, not sure I will have room for 7.1 or more before a while !!!)
    RTiA5 + CSiA4
    No surround...yet
    Pioneer VSX920
  • FestYboyFestYboy Posts: 2,346
    If there's room behind the seating area, then I strongly recommend a 7.2.2 or higher system, if not, then stick with 5.2.x. Most good units now have Atmos capability (through internal channels or external amps). Just something to consider.
    edited June 10
    No room behind the seating area unfortunately...
    By the way, I'm using my setup principally for HT and games. I would say 90% HT/games and only 10% music
    Another option maybe: Yamaha RX-A760?
    RTiA5 + CSiA4
    No surround...yet
    Pioneer VSX920
    Denon AVR-S930H is $280 at A4L with free shipping
    The Denon AVR-X2400H is $400, free shipping as well....
    Is the latest really worth the $120 difference (mainly for movies with RTiA5 and CSiA4)?
    RTiA5 + CSiA4
    No surround...yet
    Pioneer VSX920
Howdy, Stranger!
