Marine PA4A
missbetty
I am having a couple of issues with the Polk Marine PA4A system on my new boat. First, the reception is very bad. I can't pick up the stations that I could on my old boat. Plus, the ones I can get fade away when I walk away from the unit. Second, I can't get the blue tooth to recognize either of our Iphones. Thanks
Reception on boats are many times an antenna issue. Without knowing how the antenna was setup on your old boat, it is hard to compare. Many boats use the outer rub trim as an antenna, as odd as it may seem. This can be sometimes get better reception than a separate mounted antenna. I can't be of any help with the BT. This link may help. https://www.youtube.com/watch?v=_mkoPw4VVr4HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Same issue for me. I just got my boat and only issue so far is radio. Poor reception and now it keeps kicking off. Checked wiring and have not found anything loose.
Same issue for me. I just got my boat and only issue so far is radio. Poor reception and now it keeps kicking off. Checked wiring and have no sound anything loose.
It seems that there is an antenna issue with it. Have not checked it, but guess i would run the same problem.
