VAC PA100/100 with "phi" upgrade
doctor r
VAC PA100/100 with phi front end upgrade! This amp is in excellent operating and physical condition. I have rated it an 8/10 only due to age. 5 years ago I sent this amp to VAC in Sarasota for service and had the front end upgraded from its original Williamson topology to the phi topology that was currently being used in the newer phi200 amps. This upgrade made an excellent improvement in the overall sound and I have enjoyed it daily since its return. I have purchased an amp many times the asking price of this musical instrument to better my experience with the VAC. I have the original factory box and packing. Second quad of KT88 tubes and two extra quads of 12au7 driver tubes included on this forum.
Original Box and packing.
Weight approx 80lbs
Shipping to continental US only.
Shipping by FedEx ground insured
Asking: $1995.00
Weight approx 80lbs
Asking: $1995.00
integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter
rack Adona Eris 6dw
She's a beauty Doc, good luck with the sale.HT SYSTEM-
lsi 9's -
Thank you Tony. This one is difficult to part with. I have spent a lot of time enjoying its company...integrated w/DAC module Gryphon Diablo 300
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
I'm curious about this amp, curious about the tubes you've used and your thoughts on the differences. Cost, etc. If this isn't the place I'll move it to private.
oh man thats a beauty! GLWTSVA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Kharp1 - private message sent
MrBuhl, thank youintegrated w/DAC module Gryphon Diablo 300
rack Adona Eris 6dw
Yes sir,
Doc will she accommodate 6550's2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »
Yes sir,
Direct from original manual:
'Your VAC Amplifier can use 2 different output tube types: the KT88 Beam Power Kinkless Tetrode and the 6550A Beam Power Tetrode. We consider the sound of a good KT88 to be superior. Properly manufactured 6550/6550A will work, but may have a slightly higher incidence of failure in the PA100/100. Feel free to experiment with different brands and types to customize the sound to your tastes."integrated w/DAC module Gryphon Diablo 300
rack Adona Eris 6dw
Price reduced to:
$1750.00integrated w/DAC module Gryphon Diablo 300
rack Adona Eris 6dw
This is some serious gear
GlwsMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
Soldintegrated w/DAC module Gryphon Diablo 300
rack Adona Eris 6dw
