Help. I ordered my 505
kycole111
Hello,
Welcome to Polk's forum. When you say it doesn't turn on are you referring to the AC power?
Ken -
Yes that's right
That's certainly unusual, to say the least. If I remember correctly the 505 should have an AC fuse located in the same area as the point where the AC plug goes into the socket. If you remove the AC cord from the socket there should be a small door that has the AC fuse behind it. Sometimes you need a small slot screwdriver to pry open the small door.
Right I checked that already... I called Amazon I'm going to send it back
That's probably a good idea, sorry for the inconvenience.
It's not a big deal. Really
