Rubber stoppers for fxi5.
Hi
I picked up a set of used fxi5. They didn't come with those rubber stoppers / pads that go on the back of the speaker when you wall mount. Does anyone know where to get these? Emailed customer support a few weeks ago now and no answer yet, just a ticket number.
lsim705,lsim706c,fx500,rti4
rti6,csi5...no rears on system 2
  • F1nutF1nut Posts: 39,476
    The hardware stores sell all kinds of bumpers as do numerous online sources.
  • lightman1lightman1 Posts: 9,394
    Look for adhesive rubber, poly, silicone discs. Check for thickness to keep them from being too thick or thin once attached to the wall mounting.
  • tonybtonyb Posts: 28,935
    Furniture stoppers/discs can also be used and cut to size.
    Sony BRP
    Tad bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • mantismantis Posts: 14,737
    Home depot has a great selection for what you need.
    Dan
  • gurot1gurot1 Posts: 474
    Thanks. Anyone know which depth the spacer needs to be?
  • mikeyb128mikeyb128 Posts: 2,719
    Why don't you measure the rubber bumper on those nice lsifx I sent you? I believe it is similar design.
    2 channel:
    Theater:
    Lol, mikeyb128, I was thinking of doing exactly that
    So are you guys telling me there haven't been any mind blowing breakthroughs in rubber stopper technology? :p
    They won't change your sound if that's what you mean. :smiley:
    2 channel:
    Theater:
  • txcoastal1txcoastal1 Posts: 9,509
    mikeyb128 wrote: »
    Prove it :*
    2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures, Simaudio 780D DAC
    Gear on standby: Melody 101 tube pre, Modwright LS100, Unison Research Simply Italy Integrated
    Gone to new homes: (Matt Polk's)Threshold Stasis SA12e monoblocks, Pass XA30.5 amp, Usher MD2 speakers, Dynaudio C4 platinum speakers
  • pitdogg2pitdogg2 Posts: 9,651
    gurot1 wrote: »
    Bend over you tell me :p
    Won't it turn my 7.1 into atmos?!
    txcoastal1 wrote: »
    mikeyb128 wrote: »
    Prove it :*
    Oh my god, I think I just comited my first troll.
    2 channel:
    Theater:
    Here is a picture of the fx500 vs the lsifx. The lsifx has a deeper stopper. hgyr4wbxx1x5.jpg
    The stoppers are pretty well as deep as the power port/mounting bracket
    edited March 2017
    Have you looked here? If they don't have it you may not need it :p
    http://www.essentracomponents.com/en-us
    Wow, they have a large inventory!
  • nbrowsernbrowser Posts: 7,907
    mikeyb128 wrote: »
    Rubber, polyurethane, silicone etc. will all have an effect on vibration and coupling with the attached wall...you should know better...and you call yourself an audiophile and mechanic! :smiley:
    Living room: Samsung UN55KU7000 4K UHD HDR 55 inch TV, Marantz CD6004, Pro-Ject Debut Carbon, Parasound zPhono, Mac Mini, Oppo BDP-93, XBox One S 2Tb, Kenwood DPX792BH car deck for radio purposes, Marantz SR5010 AVR, Parasound HCA-1200II, Front SDA 2 modded with Larrys Rings and RD0-194-1 tweeters, Rear Onkyo SKF-4800 Towers, Center CSiA6, BOOM Tannoy TS2.12 Sub, Audioquest Evergreen interconnects just about everywhere except from AVR to amp, MIT Terminator 4, MIT AVT3 speaker cables with extra terminals covered up Monitor 5 Jr+ in the wings for a center channel.
Howdy, Stranger!
