Are Yamaha mx1000 amps common ground ?
bassfann
in Electronics
According to the amp's schematic speaker connections "A" and "C" are common ground, but speaker connection "B" is in series with speaker connections "A" so I wouldn't connect but one pair of SDA speakers to either "A" or "C" and nothing to "B".
KennethSwauger wrote: »According to the amp's schematic speaker connections "A" and "C" are common ground, but speaker connection "B" is in series with speaker connections "A" so I wouldn't connect but one pair of SDA speakers to either "A" or "C" and nothing to "B".
I got them with cut cords,and no binding posts. Previous owner didnt finish mods. Is the common ground on the board,or connected on posts ?
I believe you can find two conductor IEC sockets and cables, but if you want a three conductor connector some designers place a small value capacitor such as 0.47uF in series with the connection to ground. It looks like the wire that goes to the mains switch (SW301) and the fuses is the line/live connection.
The schematic shows the speaker "A"and "C" being grounded at the power supply, where filter caps C531 connects to C538. -
KennethSwauger wrote: »I believe you can find two conductor IEC sockets and cables, but if you want a three conductor connector some designers place a small value capacitor such as 0.47uF in series with the connection to ground. It looks like the wire that goes to the mains switch (SW301) and the fuses is the line/live connection.
