Yamaha A-S2100 thoughts
So I have been thinking of replacing my Emotiva XPA-1'S and USP-1 with an integrated to save some space in the family room and gain a cleaner less robust look.
ACL has the Yamaha A-S2100 for a reasonable price, and I really like the styling, but what are your thoughts? Have any of you heard one or have another suggestion?
Another thought is to use my ATI 2 channel app, and upgrade my pre-amp.
  • sgtmick63
    I have used Yamaha products such as receivers, int amps, cassette decks, cd players since the early 1970's. They always sounded great. They were very well built and reliable. I never had a unit fail.
  • [Deleted User]
    I'm a fan of the Yamaha sound as well.
    I was seriously considering this move or the a-s3000 at one point.
    From what I gathered, the 2100 sounds better than the 2000 and the 3000
    sounds better than the 2100 (as one would expect)
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited December 2016
    I have to have those meters, if I go with Yamaha :)
    The 3000 is well out of my budget which is around $3k for this move.
    F1nut Posts: 49,805
    By all accounts, a sweet piece of kit. Just do it.
  • Conradicles
    Conradicles Posts: 6,042
    Not sure how it sounds, but it looks really sweet.
    mhardy6647 Posts: 33,049
    What's "ACL"?
    I mean -- I need some more Yamaha stuff at my house.
    In all seriousness, that model and the even statement-ier A-S3000 seem to impress folks who've heard/owned them.
    Just looking at the A-S2100 on the US Yamaha site. Read that it has a "Superior Quality Electronic Volume Control for Optimum Sound". Whew, that's a relief! I thought it had one of them ol' fashioned Wood Fired Volume Controls.
    (I'm sorry -- I won't do it again!)
    http://usa.yamaha.com/products/audio-visual/hifi-components/amps/a-s2100_g/
  • jeremymarcinko
    I'm a little concerned that it's only 90wpc.
    Actually it is interesting to compare the specifications of the AS-2100 with the CA-1010 of 1978. CA-1010 was the second-to-top integrated amplifier in 1978, which I think (???) is at par with the A-S2100 today.
    let's see if these are legible. If not, the two manuals are easy to find -- if one's suitably interested.
    A-S2100:
    30617737323_13683c9be6_b.jpgA-S2100 specs by Mark Hardy, on Flickr
    CA-1010:
    31280385112_33a98f4179_b.jpgCA1010 specs by Mark Hardy, on Flickr
    Now -- I am not a big believer in specifications as being particularly useful (although, young and naive as I was in '78 I sure thought differently then) -- but still interesting to compare, methinks.
  • Nightfall
    Nightfall Posts: 10,072
    One of these days I will repair and refresh my CA-1010. I've had several people interested in buying it but I refuse to.
    Jeremy, go for it. I wouldn't be worried about the 90 watts, even the TOTL 3000 is only around 100 watts isn't it? I'm sure it's a very "stout" 90 watts.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Nightfall
    DSkip wrote: »
    It's not all about watts.
    How many watts is your little Dayens that you ran the big Ushers on? The answer should alleviate Jeremy's worries.
    afterburnt wrote: »
    DSkip wrote: »
    EDIT: nope, sure ain't. nor about THD+N (well, maybe at very low output power) nor damping factor nor s/n, etc., etc.
    It may be recalled that we roll with three-point-five wpc at my house. Fine direct heated single-ended triode watts; best there are :)
    No, but there are other interesting things in those two ol' manuals, e.g., the phono preamp overload points. both manuals also include some performance curves which are also interesting.
    Nightfall wrote: »
    I'm in the same danged boat with my CA-2010. I hesitate mostly 'cause, after spending money on it, I fear I'll be disappointed -- although I don't really expect to be disappointed.
    F1nut Posts: 49,805
    It's going to depend on a number of factors. How efficient are the speakers? How big is your room? What types of music and how loud are you likely to listen?
  • jeremymarcinko
    Right. I don't listen at crazy loud levels but the family room is relatively large. I don't remember exactly, but roughly 18'x24'. It would be powering lsim 705's, which are moderately efficient. I like to jam on occasion and don't want to worry about clipping.
    F1nut Posts: 49,805
    Ok, you can roughly calculate the max SPL by using 1 watt/1meter with 90dB efficient speakers. It takes double the power for every 3dB increase, which means you'd get in the 109/110 range.
    ... and...
    3 dB more for two channel vs. 1 channel
    3 dB less per doubling of distance (i.e., 1 meter to 2 meter, -3 dB; 1 meter to 4 meter, -6 dB, etc.)
    and of course -- continuous watts would translate (until the amplifier and/or loudspeakers self-immolated) to continuous dB SPL. 110 dB continuous sound noise is not so good for one's ears. Actually that's an understatement.
    NIOSH puts the safe exposure limit at around a couple of minutes, give or take; OSHA somewhat more (30 min).
  • [Deleted User]
    [Deleted User] Posts: 10,716
    What?
    ... and...
    Neither the receiver nor my amps make this list. Something to think about though...
    Rick88 wrote: »
    What color are you getting if you do get one?
    I'm partial to the silver myself. ;)
    Is there really any debate? ;)
    These suckas look marvelous in silver.
    11535696185_165df1328f_b.jpgDSC_6689_z by Mark Hardy, on Flickr
