Polk Audio SDA SRS 2.3 Crossover Modification Thread
VR3
I was able to get Jantzen to build a C-Coil this time, oh yes. I am shipping Sean one with his next build to complete his Abbot modification.
I made it to where the tweeter negative takes up one Molex entry and the inductor connection is routed through the main connection so the wiring is very clean.
Thank you- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Around 350 hrs and its like a switch has been turned on to the 2.3's every fine detail surrounded by an enveloping midrange and a bottom end that sinks into darkness....This is what its all about.Thankyou Trey...Can't wait for the SRS Abbots to the theatre rears!
