Dolby Atoms
I have 2 - 265RT as main fronts speakers / 255c RT as a Center channel / PSW505 subwoofer/ 2 - 65RT in ceiling above couch (listening area) / using a Denon AVR1200w receiver which has Dolby Atoms. Can I use the Dolby Atoms without needing more speakers? If no more speakers are necessary which speakers should I use as "Height Speakers"?
Thanks in advance!
    F1nut Posts: 49,806
    It's Atmos.
    No.
    You don't have height speakers.
    Do you have a subwoofer?
  • trj
    trj Posts: 320
    From what I read, you have 5.1 system. So, no atmos for you in the current configuration.
    For atmos, you need atleast 7 speakers(5.1.2 setup). If you purchase two more speakers and use them as side surrounds, you can use your in-ceiling speakers as atmos height channels.
    Sony BDP-S6500 | Raspberry Pi 2 | XBOX One S | Wii --> Yamaha RX-V667 --> Adcom 5006 bridged to 175 watts for front LCR -- >Front: Polk Audio RTi8s | Center: CSi5 | Side Surrounds: RTi4s | Rear surrounds: FXiA4s | Cheap 12" sub woofer|Samsung UN60KU6300
    txcoastal1 Posts: 13,132
    For an Atmos in a 5.1.2 setup you would need to surround channels at approx ear height. You would move the ceiling speakers to the .2 position
