DSW Pro 600 have trouble working
2Charlie
The light on the back is flashing. If I turned off and turned it on again, I can hear that it works for, like, two seconds then it shots off. The blue light on the front is turned off. Any suggestion is much appreciated.
More than likely the amp is bad. Call Polk tomorrow to see about getting it fixed.Political Correctness'.........defined
President of Club Polk -
Thanks for the immediate response. Is that something I can order from Polk only or can I order from other places too? And, can I replace it myself? Is there any video tutorial online?
You're referring to the amp inside the sub-woofer, correct? Is it expensive to replace?
You can only get it from Polk. I have no idea what it costs. If it's still under warranty and you have the receipt Polk will cover the part.
If you can turn a screwdriver, disconnect and reconnect wires, then yes you can do it yourself.Political Correctness'.........defined
Awesome, thank you! I just emailed Polk.
CALL THEMPolitical Correctness'.........defined
It seemed like they have a very poor customer service. I emailed them and not response. I tried to call this number 1-800-377-POLK (7655) Option 1 from their contact-us page, http://www.polkaudio.com/contact-us, and I got the busy signal. That left me a bad impression of their service. I tried to call twice.
Okay, I just got through and the part the number is de6635-a but it's going to cost like $300. That's quite expensive. And they don't sell the part online either. If it's a $300 and poor customer service, I'm not sure if I'm going to stick with Polk Audio. I'm thinking of just purchasing a whole different brand.
Hello,
I'm sorry you're having a problem with the subwoofer. I've sent a link for this thread to Kim Jasper Polk's CS manager. I'm not sure what he can offer, but he'll take everything into consideration.
Regards, Ken -
I heard back from Kim and he recommends removing the bass amplifier from the subwoofer and send it to their service center for repair. You would want to carefully wrap the amplifier in bubble wrap and place it in a sturdy box and include a short note giving them your name, address, daytime telephone number and email address and description of the problem. If you have it send along a copy of your sales receipt. The address is: Polk Audio Service, 1 Viper Way, Vista, CA. 92081.
If you've not removed the amplifier before let me know and I can provide step-by-step instruction.
Regards, Ken -
Awesome! Thank you, Ken.
No problem, glad to be of help.
