Replace old Armacell or leave it be?
Hello again,
I finally have a clear weekend to install Larry's rings and have a question. Last year I Dynamatted the drivers and PR and installed them with Armacell gasket material. The Armacell is now compressed quite flat. Should I replace this gasket with new Armacell or count on the driver resealing itself with the old material? If I replace, should I peel the old material or just add another layer?
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
Best Answers
  • motorhead43026
    motorhead43026 Posts: 4,031
    Answer ✓
    It is suppose to be flat/compressed so the drivers are tight to the baffles with just enough gasket material to keep airtight. No you don't want another layer. So if the gasket surface is intact, reuse.
    – Kevin Alfred Strom
  • leftwinger57
    leftwinger57 Posts: 2,917
    Answer ✓
    By no means an expert here, I know Jesse would say if the old original gaskets were still viable use them and nothing else. If not then Armaflex/cell is better than the old Mortite application. The compression of the tightening of the screws and rings is exactly what you want and by undoing it I doubt will hurt it's integrity. If there is really an air leak or overly compressed then just do them over again. Wait for more responses.
  • machone
    machone Posts: 1,566
    Answer ✓
    I used acetone to remove the old gasket residue. It evaporates fast so no chance that it weeps on the speaker surround.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
Answers
  • jimbo1421
    jimbo1421 Posts: 772
    I am back on this project. Thanks for your answers. I need to replace the Armacell on one driver and the PR. The material is very well stuck to the basket and shreds as I pull it or scrape it off. I wonder if paint thinner would be OK to dissolve the adhesive. Or is there a better way?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • jimbo1421
    Thanks machone. Some acetone on a Scotch-brite pad worked fine.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • It seems like with rings, you would hardly need any gasket.
  • aprazer402
    aprazer402 Posts: 3,407
    It's supposed to compress, as long as it seals all around, I would leave it alone. The rings will keep it tight.
  • jimbo1421
    On one of the drivers the gasket slipped while installing it last year. On the PR, I had to drill new holes when I put in the hurricane nuts last year. The originals were too close to the inside edge. Since the filler I used in the old holes left a small dimple, I am replacing this gasket, too.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
