Hey everyone have found a pair of 1c's for 300 is that a good buy?
Dust caps pushed in on all midrange drivers on one speaker. No sda cable, grill damaged from pet.
Srs sda 1.2TL
Srs sda 3.1 TL
Pioneer C- 90 Reference Control Amplifier
Pioneer Dv- 38a
Hafler Dh - 500
Hafler 915 Preamplifier
Hafler XL 600
Mit Magnum M1
Best Answers
  • Nightfall
    Nightfall Posts: 10,083
    Answer ✓
    Sounds like they've been rode hard and put away wet. Any of the midwoofers frozen or scratchy?
    I'd probably pass given the limited amount of information here.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Nightfall
    Answer ✓
    If all of the drivers work, might not be too bad. They look better than I thought. New grill cloth is cheap and you can make your own SDA cable cheap.
    afterburnt wrote: »
  • madmax
    madmax Posts: 12,434
    Answer ✓
    Sometimes you can use a piece of tape to pull out dust caps. I'd be a little worried though because with all of them pushed in sound like a kid poking at them for quite some time...
    Vinyl, the final frontier...
    pitdogg2 Posts: 27,848
    Answer ✓
    you can also use paper towel cardboard roll to suck them out. I have also used a vacuum but it is a two person job. 1 to turn vac on/off just that quick and one to hold driver down to keep from moving. IF YOU USE THIS METHOD DO NOT PULL OFF THE VAC UNTIL NO SUCTION AT ALL. ALSO USE FREE HAND TO HOLD DRIVER DOWN AND PUT VAC ON FIRST BEFORE EVER STARTING IT. THEN ON/OFF THAT QUICK....
    I have used it many time on Polk drivers it works but you need to be very careful I take no responsibility for pulling driver off voice coil.
Answers
  • Philinator7
    Have not listened to them yet. They are about 1.5 hour drive from me. Seller says they sound fine.
    Srs sda 1.2TL
    Srs sda 3.1 TL
    Pioneer Dv- 38a
    Hafler Dh - 500
    Hafler XL 600
    Mit Magnum M1
  • Philinator7
    Here is a picture of them.
    Srs sda 1.2TL
    Srs sda 3.1 TL
    Pioneer Dv- 38a
    Hafler Dh - 500
    Hafler XL 600
    Mit Magnum M1
  • Philinator7
    Ok, i was wondering if i would have to replace the drivers. Is that a fair price for those in your opinion, or keep looking? Thanks
    Srs sda 1.2TL
    Srs sda 3.1 TL
    Pioneer Dv- 38a
    Hafler Dh - 500
    Hafler XL 600
    Mit Magnum M1
  • Philinator7
    Have not got them yet. Will see if i can get the price down a little more. I think the guy got them at the thrift store. Will try your suggestions if i get them. Thanks
    Srs sda 1.2TL
    Srs sda 3.1 TL
    Pioneer Dv- 38a
    Hafler Dh - 500
    Hafler XL 600
    Mit Magnum M1
  • Philinator7
    Are those pretty rare speakers? Where im at this is the second pair if seen on CL. Last pair was the black finished ones.
    Srs sda 1.2TL
    Srs sda 3.1 TL
    Pioneer Dv- 38a
    Hafler Dh - 500
    Hafler XL 600
    Mit Magnum M1
