Enable carp storm, fire on my command!
afterburnt
You know I was thinking about how to phrase a question about cables and IC's but I don't figure I can do it diplomatically (without a bunch of **** arising from it). Please PM me with your suggestions regarding the performance of my system.
Thank you in retreat.
Bruce
Bruce
Just post the question.....I don't understand anyone being afraid to post an audio question on an audio forum.HT SYSTEM-
lsi 9's -
The worse thing that can happen is X shows up....lol.2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
The best way to predict the future is to invent it.
It is imperative that we recognize that an opinion is not a fact.
Imagine making politics your entire personality. -
http://m.youtube.com/watch?v=jn-UZwtLfH4
You should go ahead and have an Open Invitation, and bait our arch nemesis ol XHome Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
seems you have a good line up already. What's not to like?
I'm telling you man, I wasn't too wowed going from modded lsi15's to 705's. A pair of s1 shot guns woke them right up. They are still transforming as the cables break in.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
My 707's sound muffled compared to the Ushers, what should I do?
What is your budget? What are you currently using? What gear are you connecting? I see a lot of different stuff in your sig, that's why I ask.
I have used MIT's for years, starting mid-pack and finally graduating to the Shotgun series. One of the single largest improvements I have made to my rig.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Buget? I have no money left but if I could spend a couple of hundred or so to get an idea where improvement can be had I will give it a try. In another thread I indicated that I don't have MIT money for the time being.
I kind of think that the sub drivers are too much for the "703" top half. Is there a way to balance this? There is nothing really bad about it but I guess there is a lack of coherence in some music. wtf do I know???
Hey can I disconnect the jumpers and just run the top half?
afterburnt wrote: »Hey can I disconnect the jumpers and just run the top half?
The tweets will work but won't work or help with your issue.
How far do you have them off the wall, are either of the speakers in a corner?2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »afterburnt wrote: »Hey can I disconnect the jumpers and just run the top half?
Want to disconnect them just to see, not as a solution. Wondered if ti could hurt to run em like that? They are not really in a corner only sort of. Maybe that is the issue because they are both right next to full bookcases and one has a wall/door right behind it.
Can you take a picture?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I never figured that out. I used to be a tech wiz and now I am pretty lame, very lame when it comes to that stuff. However I never gave it much though because I have no choice on placing the speakers. Description wise: Left and Right are butted up against the bookcases on their respective sides. Behind the left is an open threshold to to dining room (partially blocking said entry). The right side is abuutting a matching bookcase and the doorway is in back of it in between the rack. If nothing else I don't have room for these speakers. I never though about the fact that these are not front or back ported, they are bottom ported so that is 360 degrees.
You can run tweeter only to see what it's like but power everything down while changing cables, and zero volume. Raise volume slowly and don't over drive.
What receiver/amp are you using? Is it your AVR?
txcoastal1 wrote: »You can run tweeter only to see what it's like but power everything down while changing cables, and zero volume. Raise volume slowly and don't over drive.
Yammaha AVR via A31
maybe these speakers need to be out in the open? -
Adjust the bass on the AVR
Set the AVR at flat2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
It is at flat. These speakers are just crazy bottoms maybe too much for music
subs are a waste of money with these speakers for HT
pull them out in the room and see what you think2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
ok I do have some room to pull them forward but maybe not enough cable. this sucks. kindda like stuffing a five pound sack with ten pounds of...uh stuff
In order for us to help you better, list the gear being used, cables, and source material. like cd's, mp3's, lossless files. As already suggested, pulling them away from a back wall would be great or avoid cramming them in a corner.HT SYSTEM-
lsi 9's -
Yamaha RX-A2030*Parasound Halo A-31Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's cd's and flacs
Bruce even if it's temporary
Try to get 3' out at least from back wall and 3' from side walls2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Tx I cant even try it, not enough cable
afterburnt wrote: »Tx I cant even try it, not enough cable
Get longer cables then....see how easy that is ?HT SYSTEM-
lsi 9's -
I am trying to lol. It will b nice to see how ther sound out in the room but they can't stay there regardless.maybe I will put em on skateboards.
afterburnt wrote: »I am trying to lol. It will b nice to see how ther sound out in the room but they can't stay there regardless.maybe I will put em on skateboards.
Well, if they can't stay there, than whats the point ?
Maybe the 707's just aren't your cup of tea ? No shame in that if they aren't.HT SYSTEM-
lsi 9's -
It's not fair to the gear (speakers in this case) if you don't/can't set them up properly to perform like they were designed. If you have limited space/placement issues you need to figure out what works best there. It will get very frustrating swapping speakers to find the right fit, unless you enjoy that sort of thing.
