Cleaning Stylus With Mr. Clean Magic Eraser
I went to King Soopers yesterday and they had two versions of the Magic Eraser. I bought both just to be safe but can I use both or is one version not safe? One is the "Original" Magic Eraser which is a standard block/rectangle. The other is "Extra Power" Magic Eraser and has wavy sides to it. There is no ingredient list on either box so I'm really unsure of what the difference is.
afterburnt wrote: »
Village Idiot of Club Polk
  • vcwatkins
    vcwatkins Posts: 1,992
    Original is the one I've seen recommended. Something is added to the others that is supposedly not good for the stylus.
  • MrBuhl
    MrBuhl Posts: 2,419
    I use the original and have for more than a year, though I know nothing about the other FWIW.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • doctor r
    doctor r Posts: 837
    Use the original with no soap or cleaners added. Place the ME under the stylus and lower it into it and the raise it up. Repeat a few times. That is all you need to do. If it is possible cut a small square and use some blue tack to attach it to a quarter to give it some mass. This is never used to "stroke" the stylus. Just dip into it. The fibers of the melamine foam (ME) have actual "sharp" edges that will scrape buildup off the diamond as it enters and leaves the foam. (Theoretically could grab the diamond in a bad way if it is stroked across it). I have used it for years with excellent results.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • gce
    gce Posts: 2,158
    Extra Power is a tighter weave that claims it lasts 50% longer then the original. Both are safe on stylus.
    Anaheim Hills CA,
    HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
  • soundfreak1
    soundfreak1 Posts: 3,414
    Been using it for a while and it works great, just don't move it while cleaning.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • TSWisla
    TSWisla Posts: 446
    I would never use either, get some LP 9 and know your stylus is safe.
    Zu Soul Supreme
    Coincident Frankenstein mkIII
    Esoteric K-07
