Proceed with caution...no polk inside
BKphoto
Nice. I hope I can start on some of my audio projects soon.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
Power hungry sucker.
Looks like a great project.
I look forward to updates on your work.
Good luck!Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
Man, thats gonna be some serious work.
Just CLEANING the IIIb's for Don was enough of a PITA.... I cant imagine sanding and then staining them lol......"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
these aren't kappa's, just a moderate, run of the mill, power needed...150 in 4 ohms is plenty
Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
EndersShadow wrote: »Man, thats gonna be some serious work.
took 2 days on and off to sand them...working from home has its perks...
I see.
Good luck with them!
I have had few Infinity speakers with Emit-K and Emit-R tweeters.
UUUGH MY EYE'S MY EYE'S what is happening to my eye's.....
J/K
carry on
lookin good BK -
J/K
carry on
lookin good BK
That's what happens when you spray deOxit to clean your eyes.
Its called, your getting old Ivan.... Go see the Eye Doctor for your glaucoma .....
Awesome!Home Theater/2 Channel:
dhsspeakerservice.com/ -
you of ALL people should know my glaucoma is well under control...If I ever get glaucoma
by the way I use De-oxit GOLD hehehe
Wow those are really looking good nice work!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
hehehehe........
Very nice. Will the muffin tins be part of the rebuild? Some type of shielding or anti-resonance treatment?Home Theater/2 Channel:
hahaha...it helps because i added binding posts that stick out, they fit perfectly into the muffin hole...
westmassguy wrote: »
Nice DIY idea.
SDA SRS, SDA SRS1.2TL, SDA-1C,SDA 2B, Soundcraftsmen Amplification (A5002s, MA5002s, MA5002As)
Ha, reading that again...I don't get much sleep around here...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
stained and cleared....
that took forever...p a i n i n a $ $
color is a little off in pic...dark mahogany, the end you see is the bottom which is bolted to a base painted to match the front...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
Beautiful!
Did the refinishing take more time than the crossover rebuild?
Seems to always work out that way for me on these kinds of projects -- cosmetics take all the time and substantive work goes more quickly.
In any case, good work!Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
thanks, yeah it did...sanding, masking off sides to paint front, masking off front to stain and clear the sides top/bottom...the flutes(or whatever they are called) on the corners took a long time to stain...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
Look Beautiful BKHome Theater/2 Channel:
Thanks...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
Very,,very nice. The stripping, sanding, and finishing is a pita but the end results is worth it.
Awesome job man!! It is always such a tedious job but the results always come out good if you take your time and do not rush. Looks as if you REALLY took your time.
