I stopped in at Transparent Music today
pumpkinman
I went to demo the Rogue Atlas Magnum power amp. The setup consisted of a Well Tempered turntable with a Dynavector 20XH cartridge, Sonus Faber 2 ways book shelve speakers and a Cronus Magnum integrated amp. This has the same power amp section as the Atlas. I really enjoyed the demo but the thing that really caught my eye and ear was the KD-CLN-LP200 ultrasonic record cleaner. I had just bought If 2 on vinyl. He played it uncleaned with a simple dry brushing. Then Barry cleaned my LP on the KD-CLN-LP200, the diff. was night and day. I want one in the worst way but with an MSRP of $3,995 it will not likely happen anytime soon.
http://transparentmusic.net/
http://klaudio.com/
http://klaudio.com/
Because I am The Pumpkinking
$3,995
man I could think of a lot of things to buy with that money! Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Pumpkin man.... Just call me your savior....
If you can DIY and I think you can.....
Hows about under 500 for the whole DIY ultrasonic kit lol...
http://thecarversite.com/yetanotherforum/default.aspx?g=posts&t=15515
https://www.tindie.com/products/VibratoLLC/6-quart-60khz-vibrato-ultrasonic-cleaner/
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Looks Great, careful around the pets though, that's funny because I use my nitty gritty and my cats just sits at my feet while I use it even when I vacuum it..ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables
EndersShadow wrote: »Pumpkin man.... Just call me your savior....
Thank you Obi Wan I'll check it out. I just might give a DIY one at shot.
P -man
I see these units becoming very affordable in the next several years. At the Chicago and Capitol Audiofest, they were selling one from Ultrasonic.com that cleans 6 or 10 lps at a time for $1,395. This one: http://www.ultrasonicrecords.com
Carl -
Looks good, maybe some day...
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Couldn't you just take something like this and modify it with a rotisserie type thing to spin the lp's while immersed ... Maybe not the most elegant but not $4G's.
http://www.amazon.com/TruPower-UC-20D-Digital-Ultrasonic-Cleaner/dp/B002E1JPCM/ref=sr_1_9?s=industrial&ie=UTF8&qid=1410097773&sr=1-9&keywords=ultrasonic+cleanerMy New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Mikey081057 wrote: »Couldn't you just take something like this and modify it with a rotisserie type thing to spin the lp's while immersed ... Maybe not the most elegant but not $4G's.
That's a great idea, I think it could work.
Thanks for the idea.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
There ya go. Had no idea after seeing all these over a grand record ultrasonic cleaners that you could get one this cheap. Then you get one of these and your under $500.
http://www.amazon.com/Saber-Rotisserie-Motor-3-Burner-Grill/dp/B00BY9YL8I/ref=sr_1_4?s=appliances&ie=UTF8&qid=undefined&sr=1-4&keywords=rotisserie+motorAnaheim Hills CA,
http://www.amazon.com/TruPower-UC-20D-Digital-Ultrasonic-Cleaner/dp/B002E1JPCM/ref=sr_1_9?s=industrial&ie=UTF8&qid=1410097773&sr=1-9&keywords=ultrasonic+cleanerMikey081057 wrote: »There ya go. Had no idea after seeing all these over a grand record ultrasonic cleaners that you could get one this cheap. Then you get one of these and your under $500.
At some point I will try this. I've been traveling a lot for work lately and am behind on things around the house. Once this settles a bit I will look into this more.
I do have a RCM now, but don't even have a turntable set up at the moment. I will get one back in before long though.
I do have experience with a lot bigger ultrasonic cleaners and they work very well...Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Nice... Just set it up with shaft and mounting system where you can put multiple LP's at once...Don't want to see you put 4 more holes in your records...
Can you get 20 guys to each kick in $200.00 per person. The cleaner would rotate among you so each person could clean all their records. Just make an allowance that if one guy had a "dirty platter emergency" he can drop by to clean his record out of turn.
Also set up a deal where for X amount of cash records can be cleaned for "outsiders" -
This is the one I have. Works great. Still working on the rotor system.
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
