Dreadnought Cases..
Toolfan66
Ok here we go!! I have already ran these on the Laser. Cases will be powder coated Black, the side panels will be Black Oxide. They will come with the holes to mount the Speakons.
I want these cases to go to those that are in the group buy first, just in case there is interest outside the group buy..
Cases will be $100 shipped.
Please post here for those interested, I know there are a couple of guys in the group buy that can't access the for sale thread, and yes I know the rules but this IMO needs to be overlooked considering the group buy.. I will make sure you guys are not over looked. Hell I guess they won't be able to read this thread anyway!! LOL!!
PM me and I will send you payment info..
Thanks!!
Thanks!!
Post edited by Toolfan66 on
Thanks Larry I need one
PM sent, thanks Larry.Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c -
payment & address sent. Thanks again Larry
in for one Larry...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Pm sent--ThanksDynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
I'm in for one as well. PM later.
Thanks a lot, I agree with you taking care of the newer guys too.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I will need 3
thanks Lar Dog . . . much appreciated
I would like to finish one or two of these boxes with an automotive finish
what do you recommend? Can I just sprayed over the existing?
forgive me but I know nothing about this painting processAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I'm in for one, thanks Larry.Jay
I need one to; thanks Larry
6 cases are paid for..
In for one Larry.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
10 cases are paid for..
PM sent for payment info.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
PM's replied..
14 cases paid for...
16 cases are paid for.
I will be picking these up from paint tomorrow, all I will be waiting for is the side panels that will be black anodized, and the hardware to put them together..
I should end up with 4 extra cases after it's all said and done after the group buy. So no one should be left out that wants one..
Thanks again guys for making this easy to get done.. -
Toolfan...at the risk of sounding totally ignorant...
What is a dreadnought case?
Thanks. -
Thanks.
You need one, if you have SDAs . . . . and it might help if you bought a 1 KVA tranny!
There might be one floating about soonAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
GlennDog:
Thanks for the reply.
I actually have Polk SDA 2B TL speakers.
What is a dreadnought case and what does it do?
And a 1 KVA tranny? What is that?
Thanks again. -
GlennDog:
Thanks again.
The "case/metal box" houses the "tanny/tansformer" and allows you to power your SDAs with non-common ground amps
You are a prime candidate for one!
GAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
GlennDog:
Thanks for the info and education.
Two of the many great things about this site are the knowlege one gains and the great people willing to share their expertise.
I run my SDA 2B TLs by a Parasound 1500A power amp which is a common ground amp so I guess I would not need a dreadnought case/tranny...but I now definitely see the reason for having one. -
"they say" that the SDA sound can be improved using the 1 KVA transformer,
regardless of amp (common Or non-common ground amp)AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
This is very true, I was shocked by the improvement. I would never use a standard cable again.. -
You shouldn't be thanking us, we thank you. You have provided us with several improvements we could not have had otherwise.
A big THANK YOU!!!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
+10000000000000000000000000Political Correctness'.........defined
President of Club Polk -
Big time. A quality cable is a big improvement over the stock cable, but then the Dreadnought brings it to another level.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
17 cases are paid for....:-)
Looks like all 20 for the group buy are accounted for..
I still have 4 extra if someone has a need for them, if so let me know!!
Thanks again!!! -
Thanks again!!!
Can you possibly hang onto one of these for me for a week? I'll know whether or not I'll have one of the transformers in the next few days. -
No Problem..
