FS/Trade? Rotel RMB-1095 5-channel power amplifier (200wpc)
jephdood
$950. The amp is in great shape. Black chassis/fins with silver middle front plate. RCA and balanced/XLR connections. TWO massive torroidial transformers inside. HEAVY (@75 lbs).
I'm not the original owner, so I can't tell you exactly how old it is. In my care it's been babied. Also took in recently to Desco Electonics (authorized Rotel service dept) where it was given a clean bill of health. I like to make sure on things before selling for peace of mind.
Selling to downsize a bit. Otherwise, this wouldn't be going anywhere.
The price is FIRM. MSRP on this amp was (I think) $2,100. They just don't show up all that often. Rarely, in fact. Also, no delivery, no shipping, and no payments other than cash. *MAY* consider partial trade for a sub. Current version SVS Plus or maybe a slightly older Ultra if in good condition. Or, maybe a 20-39pci sub to match the one I already have. Rythmik HP? Hsu 15? Possibly. Those are the ONLY things I would consider trading for.
Will get around to taking some pics later in the day.
Here's the product pitch and specs from Rotel's website:
Producing a full kilowatt (1000 watts!) of output power, Rotel's RMB-1095 is a stunning realization of Rotel's capabilities in amplifier design. It is, for all intents and purposes, a multi-channel version of the RB-1080 stereo power amplifier, already recognized as one of the finest amplifiers available at any price from any manufacturer. Rated at 200 watts per channel (all 5 channels driven into 8 ohms, 20 Hz 20 kHz, less than 0.03% THD), the RMB-1095's power supply is built around two 1.2 kVA toroid transformers. Eight 15,000 uf British-made BHC slit foil capacitors provide prodigious storage capacity and combine with 30 150 watt/15 amp output devices for uncompressed reproduction of the most dynamic source material. A sophisticated "over current" protection circuit with front panel LED indicators guards against potentially harmful operating conditions. Special "current absorbers" minimize turn-on surges while gold plated balanced XLR and single-ended RCA inputs provide easy connection to a variety of controller/preamplifiers. Heavy rear casters assist in placing the amplifier.
Model RMB-1095
Continuous Power Output (20-20 kHz, <0.03%) 5x200 watts /ch / 8 ohms
DIN Power Output (1 kHz, 1%) 5x330 watts /ch / 4 ohms
Total Harmonic Distortion (20 Hz - 20 kHz, 8 ohms) <0.03%
Intermodulation Distortion (60 Hz: 7 kHz, 4:1) <0.03%
Frequency Response 15Hz - 100kHz +0.5dB, -3dB
Signal to Noise Ratio(IHF A) 116dB
Power Consumption 800 watts
Dimensions (W x H x D) mm 432 x 237 x 410 mm
Dimensions (W x H x D) in 17 1/8 x 9 3/8 x 16 1/8 in
Front Panel Height 221 mm, 8 11/16 in
Weight (net) 34 kg, 75 lbs
Review: http://www.audioholics.com/amplifier-reviews/rotel-rmb-1095
Thanks for looking!
Model RMB-1095
Thanks for looking!
"I did not slap you. I high-fived your face."
Post edited by jephdood on
I don't see your price.
Dangit. Fixed. Thanks guys."I did not slap you. I high-fived your face."
That's better.
I have this same amp, and it is a great amp. I bought mine second hand too about 2years ago. This is a very good price for a quality piece of equipment. GLWSSony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime towers, center channel and bookshelfs (side surrounds)
Atmos: Mirage Nanosats x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables -
Thank you! Yes, it'll be missed for sure."I did not slap you. I high-fived your face."
Pictures please...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Just sold one of these last week. I had been sitting on this amp for 4-5 years. This amp is a BEAST and if I didn't decide to go Carver I would still be using it. I hope it goes to a good home. If anything you can anchor yourself to it during a tornado. 200w RMS x 5, whole chassis is a heatsink and built to last forever. I kept my RMB-1075 for lighter duty, but I will miss this amp sorely.
GLWTS!Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
I owned one of these for many years and loved it. Its powerful, clear and very warm to listen to. It never breaks a sweat no matter how hard you drive it. It's like having limitless power.
Great price my man, good luck with the sale.Dan
Be very interested when I get my 2ch amp sold!AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it -
I Owned this amp and sold it to buy a nad m25 and let me tell you the amp is a beast and really hits hard, but it is not for those of you who like warm sound. The amp is on the bright side like ati amplifiers. If you like an amp that's in your face and slaps you around Then this is it. I actually can't think of a better 5 channel under a thousand dollars. The only other amp that can a second choice is the parasound 5250 but that's it.
Interesting. I've found it to be very neutral. Not warm like a B&K by any means, but nowhere near an ATI or some of the Adcoms."I did not slap you. I high-fived your face."
Adcoms are warm units. ...I sold this rotel simply because I wanted something different. In my opinion , this rotel is a perfect match for bowers. .
The older Adcoms were warmer/darker. The newer ones, not so much. IMO.
Yeah, I'll miss it."I did not slap you. I high-fived your face." -
Jeez.. that is the first amp I have seen that has FLIPPIN WHEELS on the bottom :-O -
