Eosone RSF1000 Speakers
Tex
I have for sale a pair of Eosone RSF1000 speakers. Each speaker has 2 1 inch tweeters (one on the front and one on the back), 1 4 inch mid range, 2 6.5 inch mid range (one on the front and one on the back), and 2 10 inch woofers. I think only one is powered but I'm not sure. Amp is 125 watts. The speakers all work as they should but cosmetically they are only about a 5/10. Basically the grills are trash, 2 dustcaps on the woofers are pushed in and one tweeter is pushed in. Top caps have the gloss black finish and are in good shape. The sides are a flat black and have some scuffs and scratches. These are great for home theater but not so great for music. I bought these from a friend of mine thinking I would use them with my son's game system but really they are just in the way. My friend was the original owner. At 93 pounds each these are local pick up only. $200
Just as a heads up I am also going to be listing a pair of LS50's in black ($150) and a pair of B&W DM610 Series 3 also in black ($350). I'm just waiting to hear from a couple of locals if they want them or not. I will post them with pictures in a couple of days.
Where are you located
kevinshills wrote: »Where are you located
Safe to say they've been sold.
Post is five years old.
Good luck and hang around! -
Were Eosone pre def-tech? Because they sure do look the part somewhat
Yeah that, or older Mirage.
Thats what I've been lead to believe. My uncle had a full 9.2 setup of these at one point."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I do not remember Mirage having any bipolar speakersEndersShadow wrote: »
They sure do look like Def-Tech earliest incarnation
What??? Mirage started the whole bi-polar thing iirc...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
The Eosone speakers were initially developed, in 1995, for the Best Buy company to have their own good sounding speakers. The idea was that Polk would have Arnie Nudell design them (a completely different speaker builder from Matt Polk) and they would build them. This was done to allay any concerns from longtime Polk dealers. Later the speakers were picked up by the Crutchfield company. Polk worked very hard to keep the speaker line separate from the Polk one, hiring a different group of customer support reps, different phone lines.
Arnie's idea was to have some of the sonic advantages of planar type speakers incorporated into a moving coil type speaker. Namely having opposite polarity tweeters and upper mid-frequency drivers placed on the rear of the cabinet. The product line testing was quite rigorous with separate binding posts allowing independent measurements for the forward and rearward components. All-in-all a really good design well done but less than ideal store demonstration capabilities. -
yep you are correct. For the record I was never a fan so I didn't know their history. I go back only as far as the Omnipolar speaker. They were never big sellers in my area so I never stumbled across any at the audio stores.
http://www.miragespeakers.com/about/history/ -
Looking to replace 10 "sub drivers in my rsf 1000's and refurb the sub amp in one anyone have any info on where I can find parts and service the san Diego site must be out of business I get the runaround phone message every time
Not out of business, but no parts are available anyway.Political Correctness'.........defined
President of Club Polk -
Hey, Steelerman, I have the same situation. Did you ever find a solution? I'd love to buy your working sub amp! I'm in Pittsburgh, and judging by your user name, you might be as well.
Steelerman made one post in 2019 and has not visited since. You are barking up the wrong tree2 Channel in my home attic/bar/man cave
