is the top and bottom of lsi's paint or plastic
Flash!
Flash! Posts: 28
edited February 2009 in DIY, Mods & Tweaks
My LSI 9's have some scratches on top and bottom. If it is paint can i use some kind of scratch remover, or is the top and bottom plastic. If plastic, can the scratches still be taken off.
Post edited by Flash! on
  • steveinaz
    steveinaz Posts: 19,545
    You might try some Maquires "Scratch-X" on a scratch on the bottom as a test...I don't know if it's a laminate or some type of paint--I would quess it's a laminate.
  • MikeC78
    MikeC78 Posts: 2,315
    Depends on when they were made, the newer models are a laquer/paint type finish.
  • Flash!
    Flash! Posts: 28
    how do i find out when these were made. I bought them used. Thanks for the Reply.
    treitz3 Posts: 19,992
    I would suggest contacting Polk CS during normal hours.
