LSI hookup
lvaughnr
Hi guys,
I am a newbie. I apologise for the "basic" questions.
This is my situation.
Got three zones:
living room - 2 x Polk Audio LSI 25
living room - 4 x Polk Audio LSI FX
living room - 1 x Polk Audio LSI C
living room - Yamaha RXV 1900
Outside Patio - 2 x Polk Audio Atriums
Bedroom - 2 x FOCAL in ceiling
Home is already prewired. And I have already mounted the speakers.
How best to hook up to the Yamaha?
I am especially concerned about the living room - a bit of overkill...with the 2 floor with powered subwoofers and 4 surround speakers ...8.1 system
Any help/advice would be greatly appreciated.
Got three zones:
Post edited by lvaughnr on
Welcome to Club Polk.
Living room would be considered a 7.3 system depending on how you have things hooked up.
I would run your living room from an external amp and use the amps in the AVR for your other speakers.
Do you have a separagte subwoofer (other that the built in subs in the 25's) in your living room? If so - what kind?Mains.............Polk LSi15 (Cherry)
Thanks for your input McLoki.... I want to use the tri-zone capability of the Yamaha to run the 3 rooms.
My big concern is the living room.
For the living room I have only got the built in subs in the 25's. How do I connect those 2 powered sub woofers to the single sub output of the yamaha? And how do I ensure that the subs are not out of phase cancelling each other?
Any help will be appreciated! -
use a y connect on the back of the yami . with this you can now run both subs. if the speakers are a matched pair I would assume that they are already set up to provide proper phasing of the bass modules...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
