could it work
86_CaMaRo
sry for the mistake im new and didnt realy understand the sight and now im really confused about weather my amp will be able to handle my subs this is what i found for a good price and is what i plan on getting:
3 10" lanzarHRW104d subs
Chrome Plated Heavy Stamped Steel Basket
High Quality Chrome Plated Injection Cone
Non-Fatiguing Butyl Rubber Surround
2" High Temperature KaptonVoice Coil
65 Oz Strontium Magnet Structure
Power Handling: 400 Watts RMS / 800 Watts Peak
Frequency Response: 35-1.2KHz
DualVoice Coil System
Impedance(Per Coil): 4 Ohms
Efficiency: 86dB
2- Channel 800 watt 4-ohm lanzar vibe226
2 x 200W RMS at 4 OHMS 2 x 400W MAX at 4 OHMS
1 x 800W MAX at 4 OHMS Bridged 2 x 300W at 2 OHMS RMS
Electronic Crossover Network
Bass Boost Circuit
2 Ohms Stereo Stable
Anti-Thump Turn-On
Illuminated Top Panel
Soft Turn On/Off
High & Low Level Inputs
Power & Protection LED Indicators
Advanced Protection Circuitry
Remote Control Bass Booster
T.H.D.: <0.04%
S/N Ratio: >90dB
Channel Separation: >65dB
Freq. Response: 15Hz~35kHz
Dimensions: 11.06''W x 2.24''H x 9.25''L
is there n e way this system can be hooked up without fatalities or damaged items. once again im sry for the mistake earlier wont happen again.
Efficiency: 86dB
Bass Boost Circuit
Anti-Thump Turn-On
Soft Turn On/Off
T.H.D.: <0.04%
S/N Ratio: >90dB
Post edited by 86_CaMaRo on
I could work. You would have to wire them together to be 2 ohms, or as close to it as possible. (I would suggest a wiring combination but I don't feel like doing math right now) It won't hurt anything though, it just may not sound good. In the future, try to match the RMS output and ohms of your amp to the speakers you are connecting to it. For example, I would have bought a 1200w RMS amp for those three subs based upon the numbers. I hope this helps.
Yeah, I do think this would work! The fact that they are both products of the same developer might also help.
If something is difficult to find... It's like trying to find a **** in a Jacuzzi.
wow gold
