RTI 10's wiring help ASAP!
danny604
danny604 Posts: 5
I think im doing something wrong. I took the postive and negatives from both speakers and put them into the reciver but the speakers are only really playing the tweeter and the smaller woofer, the 2 big woofers are not even moving or giving any sound. what am i doing wrong?
Post edited by danny604 on
  • sandworms
    sandworms Posts: 1,043
    edited January 2009
    danny, a little more info is needed. type of avr, sound format, source, wire type. could be numerous reasons for no bass output
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • danger boy
    danger boy Posts: 15,722
    edited January 2009
    it sounds like you or someone may have removed the metal jumpers that go between the top and bottom speaker connectors on the back of your RTI10's... replace them with speaker wire instead.. red to red, black to black.. then see if you get sound out of them.
    PolkFest 2012, who's going>?
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2009
    Touchee Danger boy, that is exactly what I was thinking as I read his post. Hook up the jumpers (if you accidently removed them) or use speaker wire like he suggested.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • danny604
    danny604 Posts: 5
    edited January 2009
    no actually those metal jumpers are still there.
    Well I have a Yamaha VSX-815 receiver( maybe this receiver sucks, its from my old little setup)
    and a Polk audio PSW-505 subwoofer but I not running speakers through it.
    I am also using 18gauge wiring( maybe that could be it aswel.) I just dont want to have to guess rather than just fix the problem at once. thanks
  • danny604
    danny604 Posts: 5
    edited January 2009
    comon, somebody?
  • danger boy
    edited January 2009
    also check the speaker settings in your receiver.. if they are set to small for your front speakers.. you will likely not be getting any or much bass sent to them. change to large instead.. that will give you more bass and should be a full range setting.
    check that next. if that isn't the problem. let us know. there are several most tests to run to figure this problem out.
    treitz3 Posts: 19,959
    edited January 2009
    Remove the jumpers altogether and hook up the speaker wire directly to the LOWER binding posts only. Do you have a muffled sound now? Both speakers?
  • danny604
    danny604 Posts: 5
    edited February 2009
    They setting is set to LARGE for front. I have asked a few people and they all have said that my receiver is the problem. what do you think? Its a Pioneer VSX-815
  • danger boy
    even if the receiver is the problem.. you should still be getting sound from the other drivers in each speaker.
  • danny604
    danny604 Posts: 5
    I do get sound from them but its like, minimal. And also music doesnt sound nice and crisp it sounds kind of muffled
    treitz3 wrote: »
    Well do ya'?
  • danger boy
    just very odd that he's not getting sound from what now sounds like his tweeters. first it was only getting sound from tweeters, now it sounds muffled, so sounds to me now his tweeters aren't working.
    very strange. Unless somehow he's got them hooked up to the wrong speaker connections on the back of his receiver.. like surround channel connections or something like that.
  • timmythugs
    timmythugs Posts: 71
    Sounds like the crossover is bad in the rti10's!
    The communication in this thread needs a definite improvement in order to get the issue resolved.
  • infiniti16
    infiniti16 Posts: 6
    I was having the same problem with my RTi10's when I first bought them. It sounded like there just wasn't enough power and that the big woofers weren't working. I removed the metal jumpers, ran speaker wire from the top terminals on the speakers to my front terminals on my receiver and then ran a second set of wire from the bottom set of terminals on the speaker to the surround back terminals on my receiver and it sounds great now. Maybe try giving that a shot if you have the open spots on your receiver.
    50" Samsung PN50A650 Plasma
    PS3 - Blu Ray
    Motorola HD PVR - Cable
    Denon AVR- 2309CI AVR 7.1
    Polk RTi10's Fronts
    PSB Alpha C1 Center
    Polk RTi6's Surrounds
    Bose 161's Surround Backs
    PSB Alpha SubZero Sub
  • pcantando
    pcantando Posts: 1
    its def. the crossover posts i had the same problem with apair of rti6's when i hooked up monster bannana plugs i accidently thru out the red and black screws and the tweeters were no longer in the loop so make sure the posts are there and srewed down 4 times
