Which Carver AMP works best with SDA
nooshinjohn
Post edited by nooshinjohn on
Carver fans here and die hard carver fans in the Carver Forum. It used to be one forum but there are two now. :eek: I owned carver speakers but not the amp. It's been hard to find a good carver amp lately. I think they'll say Carver Silver 7 (t) or 9 (t) models or some TFM series or M1.5 (t). It's hard to get a hand on these stuff these days. Well, I am on a lookout for some myself.
I know the fact that most Polkies are also Carver regulars so I am so they will chime in for you.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Have used a TFM-25 in the past and currently have a TFM-45. Both do a great jobSpeakers: SDA-1C (most all the goodies)
I use 2 TFM 24's with my 3.1TL's
are the tfm series common ground designs? m1.5t common ground or do they need some kind of adapter?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I have a customized Carver PM1201 which works really well and is common ground. If you are looking at a Carver, or any amp, you really just need a DMM to check if it is common ground. If I was SDA amp shopping right now, I would choose the amp I best wanted for the speakers, then just buy an A1 IC from Ben and not worry about the whole common ground thing.
TFM 35 = very good
TFM 45 = better
Haven't heard any of the others, but I believe all Carvers in the TFM series are common ground except the TFM 75 (good luck finding one). The M500(t) is not common ground. The M1.0 is and isn't depending on which rev and the M1.5t is.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
If I might suggest something,, try some tubes on those 1C's and it may be the last amp that they ever see. I'm powering mine with a 40 watt EL-34 based Anthem and could not be happier,and yes, I have a TFM 45 that I tried with them for about one day,,nothing wrong with it,,but,,, tubes rule,,good luck,, let us know what you end up with.JC approves....he told me so. (F-1 nut)
george daniel wrote: »If I might suggest something,, try some tubes on those 1C's and it may be the last amp that they ever see. I'm powering mine with a 40 watt EL-34 based Anthem and could not be happier,and yes, I have a TFM 45 that I tried with them for about one day,,nothing wrong with it,,but,,, tubes rule,,good luck,, let us know what you end up with.
I'll second that. I was very impressed with Georges tube when he brought them over:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I've always wondered were the 45s and 55s offered during the same years? Seems like the 55s are placed like a newer model with an ascending rev number. A new and perhaps improved version of the 45 (though from what I've heard the 45 sounds sweeter than the 55). The RMS power is certainly close 375 vs 380.Eventually I want to find a pair of TFM-55X's
Another added bonus is that Bob Carver now will bring them to spec for only $170 each + shipping each way
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
what about the tfm-55... would this be overkill?
also found a set of silver7t's.... location a secret for now... that I may be able to get for 700.00The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
thanks guys... got a tfm35 for 200.00The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
This is an old thread but in case others are looking I will throw this out there. I have 3 sets of 1.2tl sda speakers and my first pair I wanted to run with one of my pairs of silver 9's and I can tell you from experience they are NOT common ground. Right when I hooked them up the speakers let out a massive shreak that scared the hell out of me and left me standing there in a daze for about 30 sec before I said what the hell!!!! After checking all my drivers and finding out that only one 6.5 tore the VC off the cone I was happy could have been worse. Now for the good news, I strapped the grounds together between amps and it worked perfectly. I know there was info about this when they came out because the SDA polks and carver amps were released close but I payed no heed.... I have run my SDA speaker's over the years with a variety and I tell you they really do not require much power like everyone always says. I run one set downstairs with a carver TFM-25 and it does an incredible job of controlling the monsters. Another pair downstairs I am using one of my pairs of silver 9s still. The silver 9s have a sweeter warmer sound with a very nice tube sound and great soundstage, but the TFM-25 makes my other pair dance better? Upstairs my last pair is being run by my Audio Research D-125 and for a tube amp it does an great job of controlling them. I have 3 tubes with lights on and I think that is why at medium to moderate levels the clip lights flash alot. But even with the tubes getting low it still does not distort and has stronger bass than the silver 9s do. Hope that helps someone, oh I tried all of my carver amps on my SDA 1.2tls except my TFM-75 and I will say the best sounding are the TFM-25 the 45 the 500t and the silver 9s. I dont have a 6a 22 or a 400, my least favorite was the TFM-35 and the .5t.
marcusmy2k wrote: »Right when I hooked them up the speakers let out a massive shreak that scared the hell out of me and left me standing there in a daze for about 30 sec before I said what the hell!!!! After checking all my drivers and finding out that only one 6.5 tore the VC off the cone I was happy could have been worse.
Terrible, but I'm glad only one driver was damaged. Do you have an exact replacement?
