PSW125 Power Cord
johnnymarin
I purchased this sub used and it was shipped minus a power cord. So I can't even test it. I checked the input connection and it is a 2 prong with top corners shaved at a 45 degree angle. Any idea where I can find a replacement?
Thanks, John
Thanks, John
Post edited by johnnymarin on
PC power cord? I htink someone mentioned that in a previous post awhile back.HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Welcome to CP, Johnny.
here is what you need:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10228&cs_id=1022801&p_id=1289&seq=1&format=1#largeimage
you can also get it over at your local Best Buy, Radio Shack, Computer Shops, etc. etc.
edit: you mentioned the input is 2 prongs, no ground, is that correct? then this might not exactly fitting, although I didn't see one with two prongs input.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
Thanks for the input. I'll check out the Monoprice link. I really want to test this puppy out!
John
