yamaha rxv1800 receiver and lsi9's
Flash!
Anybody Familiar with this amp? Apparently I can bi-amp my fronts with this receiver and my lsi9's. Any ideas?
Post edited by Flash! on
since those speakers are 4ohm, you are probably better off not trying to bi-amp off the Yamaha unless you contact Yamaha and find out if the amp is 4 ohm stable when bi-amping via A/B speakers or mapping the surround back channel to bi-amp the fronts.
I know the manual for my RX-V2500 talks about bi-amping the fronts by using both the A and B speakers posts. I am not really sure that it doubles the output or if it just splits the same amp to both outs which is not really what you are looking for. -
Gotcha! Do you know if i connect an external amp to the 1800 i bought it used and i don't have the manual. I would like to connect my lsi9's to a seperate amp.
Without looking, I would have to say yes. I can't imagine the 1800 not having outputs for an external amp. I think you can get the 1800's manual from the yamaha website.
If you look on the back, you should see 5 or 7 RCA outs (analog outs) plus the subwoofer out.
