Tweeters for Monitor 5
ANWKLO
ANWKLO Posts: 173
edited January 2009 in Vintage Speakers
Are these tweeters good for replacement of Peerless tweeters?
https://www.midwestspeaker.com/onlineshopping.asp
MT-4115-8
1" High End Silk Dome Tweeter
Cast aluminum plate
Great Replacement for Polk Audio, ADS and Peerless.
1000-20,000 Hz
50 Watts RMS
8 ohms
89 dB
80mm x 115mm(3.15" x 4.53") Flange
70mm (2.76") cutout
Each
Price: $44.95
Post edited by ANWKLO on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    Others have tried these.
    http://www.mcmelectronics.com/product/MCM-AUDIO-SELECT-DT-100-/LS00058
    Measure your opening to see if they are the right size. With either you may need to notch the cabs so the wires can fit, and the screws may not line up. Let us know if you try them.
    Ben
    Ben
    heiney9 Posts: 25,449
    edited January 2009
    Why not just get the RD0194-1 direct from Polk? They are the same cost and will be a better "sonic" fit although not a direct sonic replacement. I'm told it requires the use of a dremel tool to slightly enlarge the cabinet opening.
    That's what I'd recommend as the tried and true procedure.
  • ben62670
    edited January 2009
    Please disregard post #2. I just checked the schematic, and the 5 with the peerless uses the MW6502 with the 1.55mh inductor. This would place the XO point below the 2.5k minimum recommendation the tweeter I pointed out has. Wish I could edit:(
    Ben
    Ben
