lsi 9 question regarding finish
Are the sides of the lsi9 solid wood or just a veneer wood. I bought mine yesterday for what i thought was a good price of $330 out the door at a cash converters (high class pawn shop:D jijiji) They are used with some damage to the sides. It looks like just the clear coat was scraped in several places and I want to know if i can sand a little and just aply the clear polyurethane. Do you think the sides can be removed somehow to make it easier? I love these speakers so much, but i could not afford new ones, but i like my stuff to look nice.
Post edited by Flash! on
Veneer.
What's the difference between veneer wood, in this case cherry and "regular" cherry wood? I was under the impression a veneer was just a slice of the wood glued to another surface such as particle board, plywood etc.
I'm asking because I only this week received a pair of Rti a9's and one of the cabinets has a discoloration (slightly milky) which is irregular in shape and approx 1.5x3 inches. Will Polk exchange this speaker for me or is there something I can do to clean it up? This is not a scratch or scrape and is smooth to the touch. -
Try rubbing in some lemon oil. I had a piece of furniture that one of the kids put a wet glass on and it left a white spot. The lemon oil took it right out.It's all in the detail.
:cool:
HT Setup:
Samsung PN50D550
Onkyo TX-SR805
Samsung BD-D6700
Fronts: RTi10's
Center: CSi5
Side surrounds: RC65i's
Rear surrounds: FXiA4's
Sub: Velodyne CT120
Outdoor: Atrium 45's
Pictures here -
on veneer ?
I would ask Jesse (F1nut)
He`s our resident wood GuruCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
lectronicjunkie wrote: »Try rubbing in some lemon oil. I had a piece of furniture that one of the kids put a wet glass on and it left a white spot. The lemon oil took it right out.
Thanks for the reply. I tried lemon oil and it made no difference. This appears to be a flaw in the finish itself rather then a stain on the finish as would be left by a glass or a spill.
