Signal Cable Analog Two Balanced Interconnects
metal83
Do any of you have any experience with these IC's?
Post edited by metal83 on
good entry level,solid built cables.JC approves....he told me so. (F-1 nut)
Ok, well i'm still a slight bit confused on the whole interconnect thing.
Is there a big difference between the Analog Two, and the Analog Two balanced that they sell?
I'll be using a Pioneer Elite 92 and an Emotiva XPA-3 if that makes any kind of difference. -
Some components accept Balanced connectors and some do not. If both pieces allow balanced, depending on the internal design of said component you might be able to get a purer signal. Also, balanced cables are better at canceling out noise due to balanced design. The noise issue is not usually an issue unless you have a long run.
My take on it is if both pieces of equipment support it, go ahead and use it. Especially if they are both fully balanced components.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Delete
Hmm ok, i suppose now i just need to figure out if my Pioneer Elite 92, and the Emotiva XPA-3, both except balanced connectors.
Edit:
Ok, the XPA-3 does accept balanced connectors, but i don't think my Pioneer Elite 92 does.
P.S. I apologize for the big pictures, the thumbnails were not working for some odd reason. -
Just run standard RCA's. In a lot of amps the balanced is converted to unbalanced any way.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
What about XLR to RCA, or is that not worth doing? -
Not when you have RCA to RCA available. With your setup it would be RCA to XLR, and you amp most likely converts XLR to unbalanced any way so why all the extra work to have an odd cable. Its not needed, or in your best interest. Also to do it right you would need more than a cable if your amp uses a true balanced design.
Ben
