Should I go from RTi10 to RTi A5?
  • Menasor
    Menasor Posts: 283
    edited January 2009
    Well guys, my A5's arrived tonight, and first impression is that the midrange is definitely stronger than the RTi10's. I'd say the imaging is slightly better as well. I crossed them at 80 hz, so my subwoofer took over and the bass sounded fine as well. I'll have to test some music tomorrow.
    So far I'm very happy with the switch and they couldn't look any better in my opinion. Simple but elegant. I'll let them break in a bit and report back. Also, I'll be switching to Ben's IC's from Monoprice ones. I expect another jump of sound quality from that switch. :)
    Fronts: Energy RC-70
    Center: Energy RC-LCR
    Surrounds: Energy Veritas 1.0CM
    Subwoofer: SVS PC12-NSD
    Receiver: Onkyo TX-SR705
    Amplifier: Denon POA-2200 w/ Ben's ICs
    Pics of my setup (click me)
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2009
    Enjoy, should give you plenty years of happiness
  • danz1906
    danz1906 Posts: 5,144
    edited January 2009
    The A5s will sound much better after they Break-in:cool:
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • leroyjr1
    edited January 2009
    danz1906 wrote: »
    I've noticed the brightness calmed down a little also with break in
