SDA XO expertise requested
Qboneus
Qboneus Posts: 15
edited January 2009 in Vintage Speakers
I have almost finished recapping\re-resistoring my SDA 1a
I have one issue I need to tend to however; it is listed as A on the schematic i posted and can also be physically be viewed in the first Picture i posted. (schematic also shows a different value than was installed stock i have a 1000pf)?
I have replaced the stock 5 watt resistors with mills 12w and all the other caps with kimberkaps of the requisite values.
However i was unable to locate a .5uf as was stock and used a .47uf kk in its place.
I have NOT as of yet replaced this .5uf's bypass (i am thinking this is a bypass I want to keep) and was going to do this tonight.
I was thinking of using a pair of panasonic pps ech-s films with a value of .022uf for a total add-in\bypass of .044uf using the pair of ECh-S's.
this added to my .47uf KK should put me right within the stock range for this application at .514uf, To my thinking.:confused:
So the questions,
Is my thought process flawed about this application needing to keep the BP? (even though I probably need to do this anyway to get my values back within specs)
Are panasonic PPS film ECH-S capacitors worthy of being utilized as a bypass in this XO?
Does this value make sense or should I be looking at a different path to get the values I require?
Thanks in advance,
Tal
Post edited by Qboneus on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    Omit the 750pf cap. Polk may have used a 1000pf in its place. That cap should not be used when doing the upgrade.
    Enjoy
    Ben
    Ben
  • Qboneus
    Qboneus Posts: 15
    edited January 2009
    Should i add .03uf of these film caps to bring the .47uf up to the stock .5uf values?
    I am terrible at math but according to my guesstimate this puts me at about 6%(with .47's), getting awful close to 10% for my tastes.
    Anything else I should be looking at renewing?
    Thanks for the advice,
    tal
  • ben62670
    edited January 2009
    The .47 is fine. Let us know how you like the Kimbers.
    Ben
    Ben
  • Systems
    Systems Posts: 14,872
    edited January 2009
    Qboneus wrote: »
    I have used these in active crossovers and have been well pleased with them,but have never tried them in a passive xover.They should work fine in that contour part of the circuit(the.5uf is not a bypass).I would use 100volt spec.
    Testing
    Testing
    Testing
    F1nut Posts: 51,916
    edited January 2009
    As stated, the .47uF is fine and is not a bypass cap. Remove both 750pF bypass caps as you no longer need them.
    Kimber Kaps? Auricap made those, but I thought they stopped selling them.
