New system - a few questions
Ok, put in my new system yesterday. Words can't explain the thanks for the replies that I received on my previous posts, really helped me out. Just to recall my setup:
Fronts = RTi70
Center = CSi40
Side = FXi50
Back = RTi38
Sub = SVS PB1-ISD (I saved up, as suggested)
All of this being driven by a Sony STR-DA7ES, 7.1 setup. So far impressions are very outstanding. Just have a few questions. During the setup of the receiver should I select LARGE for all speakers? I also noticed while watching Black Hawk Down that most of the sound is coming from the fronts and center, which is normal I suppose. I verified that all speakers were operational with the test tones of the receiver and I did hear some gun fire here and there coming out of the sides and backs. Is there anyway to increase the volume of those speakers, I just think the sides and backs are being under-utilized? I posted a message on another forum asking about speaker calibration, I have the Avia DVD and Radio Shack meter. However, the Avia DVD suggests 85 db, as of now the highest I have gone on the receiver is -35 db, I think everyone within a square mile will hear the test tones if I went to 85 db, any suggestions?
As always thanks for the replies and so far I am extremely happy with the install thus far.
Hank
Fronts = RTi70
Center = CSi40
Side = FXi50
Back = RTi38
Hank
My 7.1 System:
Fronts: Polk RTi70's
Center: Polk CSi40
Surround Sides: Polk FXi50's
Surround Backs: Polk RTi38's
Sub: SVS PB1-ISD
Receiver: Sony STR-DA7ES
SAT Receiver: Sony SAT 200B
HDTV: Panasonic CT-36HX42
Center: Polk CSi40
Sub: SVS PB1-ISD
Post edited by hank1105 on
um...i think 85 db refers to the volume of the speakers when calibrating them, not the volume on the receiver. this means play the test tones and ajust the individual speaker volume so all of the speakers are playing at 85 db....you will have to look through your receiver manual to figure out how to do this
having the speaker levels the same might help you rproblem alittle, or it could just be the movie idk.....have fun mesin around with it sorry if i didnt help -
Set all you speakers to 'small' and the sub to 'yes' or 'on'.
Really, it should be SMALL huh. Ok, guess they are not as large as I thought. Thanks. I should RTFM.My 7.1 System:
Center: Polk CSi40
Sub: SVS PB1-ISD
HDTV: Panasonic CT-36HX42 -
Actually, you should *listen* to both settings (small / large), and see which one suits you best.
Cheers,
Rooster (of the large roosters)Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Hank,
I am also running RTi70 with PB1-ISD, and have tried both large and small options for RTi70. In my room, running RTi70 as large doesnt provide any improvement therefore I have set them as small. Running them as small does provide some benefits if I drive my system at higher volumes. In this setting, RTi70's sound much more clean and open.
As Russ said you should try both the options, but I am 100% sure that with this Sub, you will be much better running them as small.
Izafar-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
If you already know the following...please disregard.
The large vs. small speaker setting has nothing to do with the size of speaker, but rather the frequency respone of the speaker. setting the speaker to small directs all of the lowe frequency sound ( from the crossover point and under) to the sub (your .1 speaker in a 5,6 or 7.1 system). Setting the speaker to large and keeping the subwoofer may provide a more favorable low end response for your room. The only way to know for sure is to try oth options. Try setting the crosover at 80hz and see how it sounds to you. -
Fronts = RTi70
Center = CSi40
Side = FXi50
Back = RTi38
Hank
Nice speaker set up.
I agree with the other fellows who suggest you run all your speakers on small. That will direct more low end bass to your sub.. where is belongs. You'll still have bass in your fronts.. it won't go away completely. The small setting will yeild a better mix... it did for me.
With the Avia disc... i choose 75db instead of 85 db.. 85 is to loud for me.. or else I wear ear plugs when setting it up. Do one speaker at a time.. and this should help with your low no volume in your rear surrounds.
come back if you still have problems. but once everything is properly set up and calibrated.. you should be rocking your house with some very sweet sound effects in Black Hawk Down.PolkFest 2012, who's going>?
Try both, as suggested above, but there are advantages to running "small" mode, namely:
- simplified bass management, and
- conserving your AVR's power for the frequency range your speakers are capable of reproducing.
The former stems from not having multiple bass sources all of which produce reflections. While there is little risk of this being a factor below 35 Hz or so due limitations of your "5" speakers, it could be an issue in the 35 - 80 range. Sound waves will either reinforce or cancel each other at various points in your room. The more sources you have, the more likely this is to occur in abundance. Check out multiple listening positions when comparing the speaker modes, not just your primary position.
The latter is the source of the clean, open sound izafar reports. He has unburdened his amps, which are at least as, if not more, powerful than yours. The less powerful the amp, the more benefit will be realized by running speaker to small.More later,
Tour...
Vox Copuli
All of these replies are very much appreciated. I will try the small setting tonight, and I didn't know the SMALL/LARGE was more a bass thing, like a dumbass I thought it was the size of the speakers. I was just eager to hear what they sounded like, now I just have to tweak them. Thanks again.My 7.1 System:
Center: Polk CSi40
Sub: SVS PB1-ISD
I have a question about this too....
With a DD receiver, you have the option for either Large/Small for all your speakers, but with my Onkyo Pro Logic receiver, that wasn't doable....Question is, would that ultimately mean that with my Onkyo I was running my mains on Large?
Also, is it generally doable that you have speakers running Small when watching movies, but (and through a seperate player) with CD's have the speakers running at large? (or once you set to one setting, that applies to all sources running through the receiver) I don't want to have to switch the settings on the receiver every time I change sources though......comment comment comment comment. bitchy. -
The others are correct about setting the speakers to small and the sub to yes/on, under the assumption that you are using a subwoofer cable is correct. However if you are taking the left and right speaker outputs from the receiver to the sub and then to the speakers, you set the mains to large and the sub to no/off.
brettw22,
on my Marantz receiver.. it will remember the levels for each speaker when I switch between DPL, DD, DTS.. but it does not for the speaker size thing.. if I choose small. it will keep that setting for the speakers whenever i switch between the different decode settings. IN stereo it runs them (the fronts) on large, and I can not change that to small.
I don't know if this is typical for other receivers or not.PolkFest 2012, who's going>?
How do you know that it's runnin on Large in stereo mode? When I've gone to listen to some of my music, it doesn't have the punch that it used to have with the Onkyo. Also, there are times when I have tried to listen to music through my cd player in 5 channel stereo, but there's no punch........seems kinda weird.Originally posted by danger boy
IN stereo it runs them (the fronts) on large, and I can not change that to small.comment comment comment comment. bitchy. -
I have a similar setup as yours and I have set my Rti70 to small and they sound really great.
But sometimes I set it to large for music and its sounds better.
Hope it helps.
Arshad.
My setup
Front- Rti 70's
Center - Csi40
Surround - Rt600i
Surround back - Fxi50
Receiver - Denon Avr-3803
Sub - PSW350 (to be upgraded) to SVS 20-39 pci
Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
Sub - JTR Captivator S2 (Dual 18")
Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35 -
Hi,
I am planning on buying this sub (PB1 ISD) really soon. I'd just like to get some feedback from anyone who has this sub already.
Thanks,
Ray -
Ray, probably a good idea to start a new thread or search some of the past ones about this sub as it's been talked about in a few different threads over the past month or two........Originally posted by donahue
I am planning on buying this sub (PB1 ISD) really soon. I'd just like to get some feedback from anyone who has this sub already.comment comment comment comment. bitchy. -
brettw22,
the receiver just defaults to large when in stereo mode. If i play music in DPL there is little bass.. and no punch. I'd suspect it's the same when you listen in 5 channel stereo.
For the halibut, i watched Black Hawk Down last night without the sub on... and set all the other speakers to large. just to see what it would be like. Yeah it lacked some punch... but the 800i's seemed to do fairly good, so did the 400i. The sub in back on now again.
What receiver are you running now? Your Onkyo was what a T-SR600? if I remember right.PolkFest 2012, who's going>?
Now I have the B&K AVR307......before it was Onkyo TX-SV727 (circa '96)Originally posted by danger boy
What receiver are you running now? Your Onkyo was what a T-SR600? if I remember right.comment comment comment comment. bitchy. -
brett,
My B&K sets up to remember different speaker settings for each input. Your large/ small setting may be dependant upon whether you have selected sub on or off. Other than the old "consult your manual", I can't think of a way of telling what your AVR has going on other than to run some test tones.
If there's a sizable difference in your mains' SPL for a tone 10 or 20 Hz below your AVR's sub crossover point and 20 Hz above it, then your speakers may be in small all the time. Assuming your AVR crosses at 80 Hz, 60 and 100 Hz would be the test tones to choose.
If you do this with your sub disconnected and toggle the AVR between sub on/off it may shed a little light here.More later,
Tour...
Vox Copuli
WTG, Hank!
For HT, "small" for all speaks with an 80 Hz crossover to the subwoofer, ESPECIALLY with an SV subwoofer.
All the reasons for small have been well covered above, so I won't extrapolate on them.
Regarding calibration, this is critical. You need to balance all of your speaker levels, including the subwoofer, with an SPL meter and a calibration disc.
With Avia, the reason you use 85 dB is to establish a Dolby Labs Reference Level benchmark for playback. As stated above, you can certainly use a different SPL JUST for speaker balancing purposes.
If you want to establish a reference level benchmark, you MUST use 85 dB with Avia and mark down the Master Volume setting. Then when you are playing back DVDs and you want to express how loud it was, you can say "I played Blackhawk Down at 10 clicks under Reference", and I know exactly how loud that is because I can set my Master Volume to 10 clicks under Reference and it will also be (with a dB or so) the same volume in my HT room.
Set your SPL meter on C-weighted Slow on the 80 dB scale and place it exactly at head level where you will be sitting, facing forward, and tilted about 40-45 degrees upward.
Set all your speaker levels to 0 in your receiver. Start the left main channel Avia test tone and increase the Master Volume until it reads exactly 85 dB on the SPL meter. Don't touch the Master Volume again.
Play the Avia test tones for the other 4 surround speakers at the same Master Volume setting and adjust the receiver speaker level settings up or down to get exactly 85 dB for each speaker.
For the subwoofer, keep the Master Volume the same, set the sub channel level to -5 in the receiver, play the Avia sub test tone for the left main or right main, and adjust the PB1 plate amp volume until the SPL meter reads just under 90 dB (maybe 88-89 dB). If you switch to the 90 scale on the meter, it will fluctuate less and be easier to read.
Once you are done, you are channel balanced and your Master Volume is now calibrated to Dolby Reference Level. You will find that 10-15 clicks UNDER the RL setting is comfortably loud for most DVDs.
Since Avia is a true Dolby Digital disc, and you have bass capable mains, the subwoofer calibration can end up being a bit on the "light" side (even at 88-89 dB) since the main speaker in question will contribute significant bass to the subwoofer test tone even when set to small with an 80 Hz crossover.
So if you find the bass a bit underwhelming from a volume standpoint using Avia for sub calibration, that is the reason why. If that is the case at 88-89 dB, feel free to try it a bit hotter (90-92 dB) on that test tone, but don't go hog wild.
Get back to us with any questions.
I'll tell you how to calibrate the rear surrounds after you finish the above.
Doc"What we do in life echoes in eternity"
SVS -
Doc,
Thanks for the informative reply. Now I know what to do, I was totally confused before. You guys really know your s**t.
To answer the other person question regarding the SVS, all I can say is that I am glad I listened to Doc and saved up. I was all set getting a Polk and was told to save up for the SVS. The SVS is the most expensive piece in my HT system, minus the HDTV and SAT Receiver.
Funny story I shared on AVSFORUM. I was playing the Pod racing scene in Star Wars, SVS was cranked at about 1/2. My butt was vibrating on the couch, my neighbor then rang my doorbell, and thought someone fell. Her walls were vibrating, she most likely didn't think someone fell, it was just after 11:00 PM, which I admit was wrong, but my buddy and I finally figured it out. By the way I live in a condo and her walls are not even attached to mine, but her floor is
The people at SVS are extremely pleasant to deal with. The sub was a little larger then I thought it would be, but it kicks major butt.
HankMy 7.1 System:
Center: Polk CSi40
Sub: SVS PB1-ISD
Hank,
I've got a feeling that you are going to be getting to know your neighbors really well...
Edit: No common walls (or floors) for me until I'm back in diapers...
More later,
Tour...
Vox Copuli
Hank:
Some AVRs default to Master Volume 00 when the test tones are engaged. This is so you can have an easy to remember benchmark for reference level.
On my 3803, at Master Volume 00, here are my settings to obtain 85 dB on Avia:
left main: +2
center: +1.5
right main: +1.5
right surround: +5
left surround: +5
The subwoofer is set to -5 and I have adjusted the sub plate amp for about 88-90 dB.
Your Master Volume might have a 00 setting, or it might not. If it does not, then you'll just have to remember what the setting is for Reference Level.
And of course your particular speaker level settings will be different than mine; that's the whole point. If we all adjust our own systems to the same reference standard, that eliminates rooms size and speaker efficiencies and amp power, etc. from the equation.
Really, the only variable in calibrating to Reference Level is how hot you like to run your sub. Most people run it 3-5 dB hot for HT, and maybe 0-2 dB hot for music.
If your AVR has the ability to remember the sub level for different inputs, it makes calibrating for music easy.
Also, remember to get back to me for the rear surrounds when you are ready. There is a quick way to calibrate these once you've done 5.1 with Avia.
SVS -
Hey Doc, couple of questions:
What are the pros and cons of using the internal test tones vs. using a calibration disc? I dont have Avia, but have Video Essential's calibration disk. I always found a lot of differences between the settings achieved using this Disc and the settings achieved by internal test tones. Also how can we calibrate the rear surround channels using a 5.1 calibration disc?
The other question I have is that what is the difference between calibrating at 75db vs. calibrating at 85 db?-izafar
Each disc has a different calibration level to achieve a Reference Level benchmark.
Most of the calibration discs require 75 dB, but Avia requires 85 dB.
The end result will be identical though, because the test tones on the 75 dB discs (like Video Essentials) are mastered at 30 dB below Reference, and the test tones on Avia and S&V are mastered 20 dB below Reference.
The calibration test tones are always better because they play through your DVD player whereas the AVR test tones do not.
You can certainly use the AVR test tones to balance the channels and it will be close. However, they do not have a universal standard for how loud internal test tones are "mastered", and therefore you will have no idea how far off a true Reference benchmark you are when using the internal tones.
For example, when I calibrate to Avia at 85 dB at Master Volume 00, the internal test tones (in comparison) all register 82 dB. So the 3803 is 3 dB low compared to Avia. This difference is the key to calibrating the rear surrounds.
After calibrating with your disc, and without altering the Master Volume setting, adjust the rear surround channel levels to the same level as the other channels using the internal test tones. In my case, that would be 82 dB for each rear channel.
SVS -
Thanks for the advice. I will try this approach to calibrate the system. One more thing:
Do you calibrate the levels in DD setting or DTS setting? There might not be any difference when calibrating the speakers, but the subwoofer is inherently mixed with different levels on these two formats (I think thats why Denon has a separate LFE level setting for DD and DTS).-izafar
Remind me what you got danger, Rotel RSX-1065 ?Damn....8 lines...I've gotta put my sig on a diet now.... -
Doc,
All speakers calibrated as stated at 85 db and set to SMALL. Now I am impressed. I am also running the sub a little hot at around 88 db.
In the Matrix, the bullet scene was awesome, with the 7.1 setup (I know it is decoding at 5.1) sounded unreal, bullets coming all over the place.
In Star Wars II during the Jedi fight, the sabers were awesome sounding.
With this said, I am very happy person. My wife was complaining that the bathroom picture was vibrating on the wall. The bathroom is about 13 feet away, hehe.
Thanks again for everyone's help in this matter.
HankMy 7.1 System:
Center: Polk CSi40
Sub: SVS PB1-ISD
oh heavens no.. my receiver is a Marantz SR5000 with the front mains being RT800i's.PolkFest 2012, who's going>?
When DTS first came out, there was a bunch of legitimate hoo-doo about the LFE channel being mixed much different than DD. This is not really the case anymore, as the two formats are starting to achieve something of a parity.
I think there still might be a difference with DTS music tracks, but I can't be sure about that. Read that somewhere.......
I only calibrate using Avia, which is DD. I can alter the sub level on the fly during either DD or DTS playback, but I always leave the LFE trim control set to maximum, which is where it should be in my opinion for both DD and DTS DVD movies.
SVS
