Amp for SDA 2B's
chandler9a
chandler9a Posts: 878
edited January 2009 in Vintage Speakers
Hello, I enjoy all of the information on this forum regarding the wonderful SDA line.
I was wondering if anyone had some information of whether or not the NAD 2400 or 2700 two channel amps would A: be a good match for my sda 2b's? and B: are they common ground so as to actually work with them at all?
I am also considering the Adcom GFA 545.
Any advice would be greatly appreciated
Thanks!
Post edited by chandler9a on
  • fbm211
    fbm211 Posts: 1,488
    edited January 2009
    I dont think the 545 is common ground and if not you can tie the neg posts to make it so
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • davidk0512
    davidk0512 Posts: 157
    edited January 2009
    I have the Adcom 555, 545 and 5400, all are common ground.
    I also have the NAD 3400PE integrated, which uses the same 2400 amp. This NAD is also common ground. I have driven a pair of SDA 1Bs with the Adcom 555, but have since moved them to a room of their own driven with the NAD 3400 which really opens them up. The Adcom sounded great, but I do like the NAD much better.
    David
  • chandler9a
    edited January 2009
    I currently run the SDA's off a Sonny 555es which I love. I think its around 110 wpc, but I am assuming the NAD 2400 would be a significant improvement.
    any thoughts?
    -Aaron
  • chandler9a
    edited January 2009
    Thanks for all of the info! I ended up going with the GFA-555. I wanted a little more power
  • NJPOLKER
    NJPOLKER Posts: 3,475
    edited January 2009
    davidk0512 wrote: »
    I am positive the Adcom 5400 is NOT common ground.
