So, any Steak Lovers here?
[Deleted User]
I have been into Steaks lately, alot. I have been experimenting on different ways of seasoning it, and been trying to find the ultimate steak. Of course, everyone likes it a certain way, with a certain taste.
I have tried the normal salt and pepper route, its boring. I tried the mustard and pepper route, got old and boring. I tried, oyster sauce with garlic salt, getting tired of it. I tried soy sauce on one side and oyster sauce on the other, but it turns out like pork chops.
I am sure, many on here gotta have a certain way of seasoning the steaks.
Anyone, willing to share a recipe or two? No Kobe steaks way too much!
Halen
Halen
A nice rib eye or filet mignon liberally coated with Mccormicks grill seasoning cooked to medium rare. YUMMO!!!!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I dunno, I always liked mine with some garlic salt and Worcestershire sauce. Marinated with those things is good, throw in a packet of onion soup.
I love a good steak too. For home cooking I like like a good filet- also with McCormick's like cfrizz
I don't grill a lot though, and here in the Seattle area we have some great places to go for a good steak! -
I have experimented with every different cut of steak and every different marinade or rub. I have come full circle, no matter the cut - the only thing i ever use now is Montreal Steak Seasoning. It is delicious.Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
I always like ot use the following for steaks:
Paprika
Kosher salt
Black ground pepper
Add a little chili powder to spice things up.
Actually just had steak tonight. Yes.. it's cold out there but I grill outside all year round. Just make sure you get thick cut steak. Not the best but Costco usually have decent meat.Main Gear
Panasonic 50" Plasma, Polk LSi15 (Front), LSiC, LSi7 (Rear), Sherwood Newcastle AVP-9080, AM-9080 bi-amp to LSi15, AM-9080 bi-amp to LSiC and LSi7. -
Get a Big Green Egg.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
I either throw it on a seasoned iron skillet and chuck it under the broiler to cook to taste. Or if it's a grill, I only use charcoal. Propane and propane accessories are just so bland.
I don't use seasoning unless it's fillets and they are thick then I wrap some bacon around the edges and pin it up with a toothpick if I have to. The bacon dries out instead of the edges of the steak and the bacon fat, especially from smoked bacon, gives just a hint of extra flavor.
It's been my experience that while seasonings are nice, a properly cooked steak needs no help.
Two things you shouldn't do:
1.) DON'T POKE IT! Don't use a fork or anything else that is gonna jab holes in the steak. Holes let juices leak out and dry out the steak. Use tongs to flip the meat.
2.) Throw the meat on a very hot grill, broiler plate or skillet and sear the first side for a minute and then flip and sear the other side for a minute. Reduce the heat and flip back over and let cook 4-6 minutes depending on thickness on the first side. Flip it again after 4-6 minutes and let cook 4-6 more minutes. Check it on both sides if you like and then plate and serve. A typical 6-9 ounce fillet shouldn't take more than 8 minutes to cook. Of course thicker steaks will need more time for higher levels of "doneness". But 8 minutes should get you medium to medium well in most cases on an amply hot fire or broiler.Expert Moron Extraordinaire
I eat like a pauper 5 nights a week, just so I can treat myself to a Filet Mignon from Fresh Market.
$20.00 a lb., I usually get 2 steaks out of one lb. Just a little Lowry's seasoning salt, and I'm GOOD to go!!
I am a CARNIVORE!!!! And until they can make tofu look, cook, smell & TASTE like a bacon wrapped tenderloin, don't waste your breath!!I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Also- if you ever get a chance to have a good Wagyu steak in Japan, it's AMAZING! Best steak I've had in my life, it just melts in your mouth
Bleu Cheese...use as a topping after cooking.Even If your not a fan of bleu cheese give it a try,the flavor of the steak really mellows the cheese and the flavors blend well together.Outlaw 990 Processor
Outlaw 755 Amp
Denon 2900 dvd-sacd
Dishnetwork HD-Dvr
55" Sony LCD RPTV
Lsi 9-fronts
Lsic-center
Rt55i- surrounds
Velodyne cht-10 sub
2007 Dodge Quad cab
Kenwood Excelon KDC-X891
JL Audio 300/V2
Polk Audio SR 6500 - Fronts
Polk Audio DB651 - Rear
2 -10" Treo Subs
Interfire IB 2600C sub amp
Sirius Sat radio
Ipod connection -
Mccormicks grill seasoning for me, med to med rareDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
EVOO with sea salt, cracked pepper, and crushed garlic. Not a lot of any except the steak. Med.2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Oh my! I am eating steak as of this moment.. So far so good, all the recipes sound so enticing, its making my steak taste like its boiled! I am gonna try every one so far mentioned! Damn.. Keep em coming!
Halen -
Noooo....That's for Ham silly!
Correct....when you're not cooking a steak. :cool:
Little olive oil, sea salt and pepper. That's it. If that's "boring" to you, you don't like steak, you like marinades.If you will it, dude, it is no dream.
Me, a steak lover?
Is a frog's ****$ waterproof?
I'm Keiko on this one... sea salt and LOTS of fresh garlic. I prefer my steak seared over a wicked hot charcoal fire. Serve it french fries that have a good dose of German Pommes Frites Gewürzsalz. -
It's like going to a nice steak house getting a $50 steak and then asking for some A1 sauce.
Main Gear
Boring, if you eat the same thing over and over and over... and over... What I meant is the seasoning. So many ways to steak a steak out there. Why not use this as an opportunity to learn, embrace new ideas right?
As far as marinades.. hmmm.. I do that a lot, its not about attacks, I am just open enough to try different things.
Unwinding the day with a good steak and music. Keep them coming..
Halen -
And, I know longer dip steaks into anything after it leaves the fire and ready for devouring. Yummy... Come on. Its not just me, the recipes are for everyone on this forum as well to try. If you like to dip it into some awesome sauce you got, then hell, I wanna know it, just not the typical premade stuff from supermarkets.
Halen -
Correction.. previous post of mine.. I meant I "no" longer dip steaks into anything.. Just enjoying my night... Meat and wine among other things...
i have experimented with every different cut of steak and every different marinade or rub. I have come full circle, no matter the cut - the only thing i ever use now is montreal steak seasoning. It is delicious.
+1 for Montreal's!"Wish I didn't know now what I didn't know then." Bob Seger -
peppercorn sauce, heavy on the pepper, can have added brandy and mustard, preseason with salt and pepper before cooking and start with the steak at room temperature before throwing on the heated pan if able............mmmmmm
PS if you can still feel your tongue and lips after the meal you need more pepper;) -
+1
Montreal, a couple bay leaves, and some worcesteshire (sp?) in a ziploc at room temp for about an hour. mmmmmmmmmmmmmmmmmmm"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason." -
sometimes i get a sirlion tip roast and cube it up and marinaded it with a little granulated garlic and soy sauce,then get the iron skillet and sear it good,then i add a little chopped up fresh pineapple fine and stir that in for a minute and then cover it and put in the oven on about 325 till done.comes out pretty good:D
soak steak in lemon juice overnight and season it with "Red robin" seasoning and meat tenders... Yummmmy..
I prefer porterhouse or NYStrip,,
damn, i want steak for lunch!!I am 100% BORN DEAF and No I am not kidding!
Why am I here? My wife's hearing!
My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA -
DAMN YOU GUYS!!!! I just ordered Philly cheese steak for lunch!!!
:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:D:D:D:D:D:D:D:D:D:D I am 100% BORN DEAF and No I am not kidding!
Stubbs Beef Marinade on any good cut of meat on a HOT A$$ grill. Dont get any betterLife without music would♭
To each his own, but I think a good cut of steak should not be masked by a marinade or a sauce. If you have a strip, porterhouse, or filet all you do is sprinkle a little sea salt and fresh ground pepper possibly a touch of garlic or olive oil to prevent sticking cooked to medium rare. But then again, I also use sirloin tips to make ground beef. I don't care rib eye becuase of the fat.
I'm partial to T-bones, with a fairly liberal sprinkling of garlic salt and fresh ground pepper. Since I only eat steak every other week or so, it never gets boring!
I too love a good steak. When we can, which is once or twice a year we order Kobe steaks and BBQ just like that, nothing on them.
For reg steaks try this :
1 bottle of Balsamic vinergrette (we use Paul newman's)
couple cloves of garlic pressed, or chopped very fine
and add soya sauce to taste. Marinate over night and enjoy !
Sometimes we add portobello shrooms to the marinate with the steaks and BBQ them as well.
Damn I'm hungry now !!!:(
