Remote for Adcom pre
Willow
Willow Posts: 11,231
edited January 2009 in Electronics
I'm bidding on an adcom gtp 450, it says it's remote capable but no remote, any idea where to get one or should I just buy a lower model harmony to operate it?
Post edited by Willow on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    Check out the Harmony 520. They are $39 at Amazon.
    Ben
  • Willow
    edited January 2009
    Sweet thanks
    Ben, what is the shortest IC you would make? I know off topic, but it's my thread..
  • ben62670
    edited January 2009
    I don't like to make them shorter than 24". The connectors grab real good, and any shorter you might break the cable removing them. They don't have a rip the jack out grip, but it is nice and tight.
    See you in May?
    Ben
  • Willow
    edited January 2009
    Tickets are booked, so for sure you will see me in May! looking forward to it!
    I'll be looking for some shorter ICs for my new 2ch system. I'll shop around.
  • ben62670
    edited January 2009
    Cool it will be nice to meet up with ya.
    Take care.
    Ben
    Ben
